OK, i have complete the RR plugin, didn't take long at all...
only 1% of RR commands are supported by this tuner
lots of limitations here..
for one, i cannot retinue the tuner to the last freq, when RR restarts... hopefully the tuner remembers that on its OWN... i have no idea...since i dint have one
and cant officially power off the PC I'm testing with, or hibernate it
no RDS data or DAB data is available
commands:
audio needs to be managed by the LINEINCode:next, prev freq+,freq- tuneup,tunedown all do the same thing, which is "scrollup" & "scrolldown" or <</+ -/>> band - switches between DAB & FM dabscan - does a DAB SCAN (also some seek/scan thing in FM) dabselect - select/nav button dabdisplay - changes display view dabmenu - menu button dabpreset;x - x = 1 - 10 dabpreset,x;s - x = 1 - 10, will save the preset (works for fm too)
since i cannot even MUTE this tuner reliably
there are NO Playlists, nor direct tuning, since there are NO commands in the firmware for this...
i might consider, adding, the results of a dab scan, into a PLAYLIST...
but that is a TO DO item, since it doesn't fit any actual RR structures
and currently there is NO SKIN that supports this...
someone who has some talent, needs to contact me, and test, and make a base skin
so others can skin off that.... its not too hard
LinkBack URL
About LinkBacks
