Page 37 of 170 FirstFirst ... 27282930313233343536373839404142434445464787137 ... LastLast
Results 361 to 370 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #361
    Apr 2010
    Ok. Just to update everyone. ALL outstanding orders have now gone out. We are now in a position where we have stock of these units ready to go out so all orders will now go out within 1-2 working days of the order being placed.
  2. #362
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    CF Plugin loads but does nothing, no buttons on the page work, radio wont turn on.
    Live mp3Car Facebook Chat
  3. #363
    Apr 2010
    I take it the test software works ok? If so, have you selected the port correctly in settings and also set the latency to 1ms in device manager? Also try installing http://www.craigbrass.net/vcredist_x86.exe
    If that doesn't work, I should be posting another build today which you can try.
  4. #364
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by craigbrass View Post
    the standalone works fine for me, and i'm pretty sure i have the runtime files already installed as i use VS2008 on this PC but i'll try it anyway
  5. #365
    Jul 2010
    Sonicxtacy02 - how did you managed to make it working, im using CF3.1 and is not showing anywhere, did u put it in plugins folder?
  6. #366
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by zenonek View Post
    yes thats all i did.. put it in the plugins folder then assign one of the main cf buttons to it.
  7. #367
    Apr 2010
    Right. Try http://www.craigbrass.net/ultimate_radio.zip
    It should fix it for anyone who has been having problems. You need to assign a button to it in Settings, though, after adding in.
  8. #368
    Jul 2010
    Ok, got everything needed now.
    Can now give some feedback.
    Radio unit is great. I bought this DAB aerial http://www.dabonwheels.co.uk/Kinetic...ar_aerial.html
    Great people, next day delivery first class post.
    Windows aplication without any problems, not really sure what function dab radio should have, but this one has all i need. Auto scans for stations too.
    Centrafuse plugin needs some more work, but is preaty usable.
    I had some problem with it, was geting stack on searching for stations, i had to use hard reset a few times, due to having no keyboard in the car.
    But is sorted now, this is what i did: Windows application had to be runed first, switched for dab, then radio switched off, disconnect. close the application.
    Then run CF.
    Scans for statin with no problems, just to take a long time to switch between stations, i was thinking that was not working, and started to press other switches... need to be little patient with it.
    Before i switch the ignition off and comp go to hibernation radio needs to be switched off. because on wake up station lists gone and no sound. Have to switch the radio off and back on again to work.
    Also will be good if line in mutes when i make a call from centrfuse plugin.
    Good work Craig, i hope we will have updated plugin sun.
    Also im trying Ride runner now due to phone issues with Cf, can i have RR plugin for Ultimate Radio?
    Thank you
  9. #369
    Apr 2010
    Thank you for the review zenonek. The glass mount recommendation is interesting. I tried another one that I think only had 3 stars on their site and had nothing but problems with it but that is the one all previous customers got emailed about about a month back and has 5 out of 6 stars so....
    The Centrafuse problems are being worked on and main issues at the moment are :-
    - We need to use the default Centrafuse header allowing you to switch stations when in another plugin.
    - We need to route the audio from line in to speaker out. This will fix your mute issue when in a call.
    The remainder of issues are just small bug fixes including the hibernation issue which I *THINK* has been fixed in today's build finished an hour or so ago but I am yet to test this so we'll see. It is just a case of powering down the unit and then disconnecting the virtual COM port on shutdown / hibernation / sleep and then reconnecting as soon as it comes back online.
    The RR plugin is being done by Mitch and I have sent him a unit for testing with. I am working with him via email and a release will happen shortly with a bit of luck.
  10. #370
    MySQL Error
    Oct 2004
    zenonek, the RR plug in is done, along with sample skin
    im looking for Experienced RR users to test, so I dont know where you fit in
    since you use CF... PM me if interested
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
Tags for this Thread
