Page 39 of 168 FirstFirst ... 29303132333435363738394041424344454647484989139 ... LastLast
Results 381 to 390 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #381
    Dec 2007
    Sydney Australia
    Quote Originally Posted by peter_f View Post
    My Dab radio works in RR but I have nothing in the Info window. Has it worked for you without changes (e.g. font) ?
    With Dab_master.exe I have the proper info display.
    Yes Peter, it worked for me without changing font but you need to get the Venice7 module plugin and RR skin from Mitch as he mentioned on p24 previously. You should not be using the existing Venice5 radio configuration in RRconfig.
    He will give you instructions on where the plugin needs to reside in the RR directory structure.
    After that there are 2 changes you need to do to RR.ini manually and will have to re-do if you alter the Radio part of RRconfig.
    - go to the [Radio] section
    - Radio=Venice7M
    - RadioPort=(the port your module is on as shown in DAB_Master.exe when you connect)
    Quote Originally Posted by veletron View Post
    It would save having to select a com port in the setup
    Nigel, I have disconnected and reconnected the module, rebooted the PC and restarted RR many times and not once did I have to alter the RR.ini file for the COMMport the DAB radio was connected on after the initial setting so it seems rather reliable and hassle-free at the moment to me. Cannot comment on CF though.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  2. #382
    Jun 2010
    Quote Originally Posted by RevheadKev View Post
    - Radio=Venice7M
    Had the link already from Mitch and had already done the above described procedure. But in the venice7 skin I have this little window where the info should be, and this is empty. The radio plays in the background, so it is initialized by RR plugin. The buttons seemed to work, I can switch to FM ...
  3. #383
    Dec 2007
    Sydney Australia
    What RR skin are you running ?
    The Venice7 module RR skin Mitch did is for the Carwings Dynamic Lite.
    I changed to this and it all worked straight away.
  4. #384
    MySQL Error
    Oct 2004
    Revheadkev, please do not clutter this thread with images or such of the RR plugin, contact me directly...you are the 1st person(outside myself) testing it
    also, TURN OFF USE LINE IN PLUGIN, clearly you dont understand what thats for...
    hense the second winamp... and set your RadioLine=x to the correct line, so that audio is managed
    the FONT you got seems giagantic.. its just Arial, i do calculate font size based on the window size, but assumeing you didnt touch that you font seems way to big!
    peter_f, same... PM me,
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #385
    MySQL Error
    Oct 2004
    ANYONE using RR PLugin for the Venice7, the version of RR MUST BE the newest (07-01-2010)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #386
    Jul 2010
    Quote Originally Posted by craigbrass View Post
    @Roadwarrior: Thank you for the review.
    @zenonek: Can you try the Windows standalone plugin. Does this crash at 98%?
    the standalone windows pluginn cannot open, it show ,essage "THE APPLICATION HAS FAILED TO START BECAUSE ITS SIDE-BY-SIDE CONFIGURATION IS INCORECT, PLEASE SEE THE APPLICATION LOG OR USE THE COMMAND LINE SXSTRACE.EXE TOOL FOR MORE DETAILS.
  7. #387
    Aug 2005
    Iceland
    Here below are some pictures how I installed the module in a box.
    This will go into the trunk of my car. In the box is also DCDC USB power module that I recently bought.
    At the moment all is working very well and mitchjs plugin and skin is working perfectly.
    I want to give craigbrass, mitchjs and all that have worked on this module a big thank you for this BIG upgrade to CarPC radio section from HQCT.
    I will give you next update when I have installed it in my car again and tested it in the "nature"
    craigbrass, mitchjs, this is for you --------> from me, one happy customer in Iceland
    2005 VW Passat FSI 2.0
    Iceland
  8. #388
    Jul 2010
    So, i'm tempted to get this, but i'm a bit nervous as i am new to all this.
    Is this going to be easy to install and get running? or is there a lot of messing around to get it to work?
    I've got everything else i need except for the mobo/ram/hdd to get the CarPC running and they are on their way..
    Oh, and how long will the introductory price be going for? Aussie customer btw..
  9. #389
    MySQL Error
    Oct 2004
    RR Plugin Updated... for those testing, its on the SKY Drive...
    fixed skin issue, so make sure you copy over the CDL skin files
    and just run the installer as normal, version at 1.0.0.2
    minor change, a gui thing, i didnt like the signal strength bar, happier with it now
    and window was too big
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #390
    Dec 2007
    Sydney Australia
    Quote Originally Posted by Sledge1 View Post
    What frontend are you running Sledge ? Centrafuse or RideRunner ?
    For RideRunner, it will be a very easy install and get working. The plugin from Mitch is great.
    Centrafuse I can't comment on, but I hope others will.
Tags for this Thread
