Page 4 of 170 FirstFirst 123456789101112131454104 ... LastLast
Results 31 to 40 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #31
    Jun 2006
    Quote Originally Posted by theonlykid View Post
    What is the advantage of using this tuner over the FM tuner with RDS from Car TFT?
    The following countries use Dab/dab+ which is an open standard (as opposed to hd Radio), UK, germany, france, italy, spain, norway, sweden, finland, denmark, switzerland, austria, australia, new zealand, s. africa, canada
    car pcs and especially their power supplies give off noise which can make fM and AM reception poor.DAB is a digital signal and much more immune to interference.
    this radio will pick up FM as well but i didn't design my board for that. I am planning on modding the board slightly to improve fm performance but frankly if you have dab you won't go back.
    I don't want to knock the cartft tuner but that is very similar to the sliabs radio which didnn't give me as good reception as this one. Even on FM.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  2. #32
    Dec 2008
    Quote Originally Posted by nrgizerbunny View Post
    What CarTFT tuner are you talking about? I can't find any DAB tuner at http://cartft.com.
    Did you instead mean the Dabby tuner from DigitalNow that was linked to earlier in this topic?
    http://www.digitalnow.com.au/product_pages/Dabby.html
  3. #33
    Low Bitrate SoulR's Avatar
    Aug 2007
    Hi Chester,
    Have not seen that USB Dabby radio before, as for the Bush Radio it is a bit of a process which i have not currently done as yet, your best to look at the digital-car forum for further details
  4. #34
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    Question
    There is a dll available for this radio so you can use whatever you like to code it. Full schematics are available on the digital car website which was linked earlier in this thread.
    Thanks, but I can't find link to any SDK/DLL likns, can you please link it here again so I can take a look at that before I order a receiver from you.
    And the module is it "Venice5.1" that support DAB+ ?
  5. #35
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by Jeep View Post
    The 5.1 support dab+ but as yet there isn't a dab+ project (no software exist yet for dab+)
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  6. #36
    Raw Wave
    Jun 2003
    Quote Originally Posted by Griff1 View Post
    The CF3 plugin is a DAB+ compatible based on the 5.1 module.
  7. #37
    Jun 2006
    Quote Originally Posted by Blues View Post
    I probably didnít word my response very well.
    What I actually meant to say was, the CarTFT FM USB radio is based on a very similar chipset to the silabs/ADS radio that was the rage around here not so long ago.
    In my case the FM reception on that radio was poor, this doesnít seem to be isolated either
    The FM reception on the Venice is much better even though my test PCB is optimised for DAB. I didnít give the FM side of things a thought and it is still heaps better. Iíve got a dead spot but I think I can fix that.
    The inherent problem is not the radio as such, itís the power supply, for instance when I use my EEE PC I get perfect FM reception across the board because its running on batteries, when I use an Opus, I have no problems, when I use an M2-ATX I get a slight hiss and static on certain FM frequencies, AM is unlistenable. On DAB there is crystal clear reception on every station.
    Visit my Homepage
  8. #38
    Jun 2006
    I'll stick this up on my website when I get home.
    Visit my Homepage
  9. #39
    Jun 2006
    the problem with DAB+ is, as most of us are in the UK, we have no way of testing it. So basically we can send the software out but cannot guarantee it will work. The DAB will work as we can test it.
    Visit my Homepage
  10. #40
    Mar 2010
    Quote Originally Posted by Ricky327 View Post
    Are you talking about the plugin from Andywhittaker, the plugin from Chris31 or a new plugin that I've not come across?
    If it's one of the above plugins then I think you are wrong (please correct me if things have changed since I last looked), both Chris31 and Andywhittaker use the same Venice5 as the rest of us and not the Venice5.1.
Tags for this Thread
