Page 43 of 170 FirstFirst ... 33343536373839404142434445464748495051525393143 ... LastLast
Results 421 to 430 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #421
    Apr 2010
    Thank you for your feedback. Those are all issues we are working on. A new build tomorrow / Tuesday should sort the majority of them.
  2. #422
    Newbie Asterix1965's Avatar
    Jan 2007
    Hello Craig
    I received the radio but for now I could make some serious evidence as I miss the SMB-F connector, I'm looking on ebay and just buy it and I arrive I will be happy to give you my impressions.
    PS. My system consists of Windows 7 and Riderunner and I downloaded the plugin Riderunner Mitch
    Hello Asterix1965
  3. #423
    Jul 2010
    So the standard antenna plug in cars.. what connection is that?
    Will i be able to plug that in and it will work? or will i need a new antenna fitted somewhere?
  4. #424
    Apr 2010
    Standard for FM is the Motorola connector. Standard for DAB is SMB (connector on this unit for combined DAB and FM).
    Depending on the FM aerial, you may be able to just get a Motorola to SMB cable but you may find this doesn't work and need a dedicated DAB aerial or to replace your current one with a combined DAB / FM aerial.
  5. #425
    Dec 2007
    Sydney Australia
    Hi sledge1,
    A couple of us in AUS will shortly be getting an SMB-BNC cable with a BNC-motorola connector to test my standard roof-mounted amplified antenna and their standard fender-mounted extendible non-amplified antenna. This should let us know which antenna will or will not suit both FM and DAB+ reception here in AUS.
    I expect the items to arrive in the next 2 weeks from the US so it won't be long after that we will be posting our results.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  6. #426
    Apr 2010
    Great stuff. Looking forward to hearing the results.
  7. #427
    Jun 2006
    Quote Originally Posted by RevheadKev View Post
    Hi sledge1,
    if you guys get stuck let me know and i'll sort out some SMB to Motorola Connectors. Depending on how good or bad the signal is, you may lose a bit through the impedence missmatch of connectors. I think by default BNC is 75Ohm, SMB is 50Ohm, Motorola can be 50 or 75 Ohm.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  8. #428
    Dec 2007
    Sydney Australia
    Hi nrgizerbunny,
    Your post got me thinking, so I have done some research (googling) and found that rg316 cable is 50-Ohm, SMB connector is 50-Ohm, car radio antenna cables are 50-Ohm and BNC is usually 50-Ohm except for Broadcast BNC which is 75-Ohm (according to specs on the Amphenol website).
    Since the cable I will be getting is an SMB-BNC with rg316 then I HOPE the BNC will be the 50-Ohm type. Also since the BNC-Motorola adaptor has the 50-Ohm Motorola end then I ALSO HOPE the BNC on this connector will be the 50-Ohm type.
    Got any clue how I could test the impedence when I get them ?
  9. #429
    MySQL Error
    Oct 2004
    i have some car stero adaptors here for am/fm and they all using rg174
    you can get rg174 with a smb preterminated...
    then get some meta 40-UV45 the solder type motorola ends...
    and make a nice short adaptor, like 6 "
    at least one doesnt then have to deal with the coax crimp
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  10. #430
    Vendor - Mo-Co-So
    Nov 2005
    Mitch is right all of the antenna adapters we have are rg (radio grade) 174.
    The cable you are looking for already exists. We normally use it for the HQCTi. If whomever is selling these tuners wants to contact us we could do bulk pricing on them.
    http://www.mo-co-so.com/SMB-to-Motor...-hqcti-smb.htm
Tags for this Thread
