Page 45 of 170 FirstFirst ... 35363738394041424344454647484950515253545595145 ... LastLast
Results 441 to 450 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #441
    Dec 2007
    Sydney Australia
    Hi PaulC,
    The Blaupunkt FM/DAB antenna ... does it have one or two (FM & DAB) cables ?
    Have you only tested the DAB or have you also tested the FM part of the module ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  2. #442
    Apr 2010
    Thank you Paul - glad to have another satisfied customer!
  3. #443
    Apr 2010
    Hi
    This test was only done with the DAB antenna connected at this stage. (FM not too good) The next test is to get the FM side connected and working
  4. #444
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by 0471430TK View Post
    The multiplexer for simultaneous FM and DAB aerial connection is high on my wish list. DAB coverage is lacking in many parts of Norway and FM will have to be used frequently.
    I use this antenna which works fine for both DAB and FM without the need for any multiplexer here in Norway.
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  5. #445
    Jul 2010
    Norway
    Thanks for the advice, Borte. I'm afraid though that antennas with a rod not always is an alternative for tall cars. There will be problems with ceiling clearance in certain parking garages.
  6. #446
    Jul 2010
    How do you fit those antenna's?
    Do you need to drill a hole in the roof etc?
  7. #447
    Apr 2010
    Well they are designed as replacements for existing roof aerials. You just unscrew the nut on the inside of the car and take the old aerial off. Slot the new aerial in and screw the new nut. I always pour water over it for a few minutes to confirm there isn't a leak.
    If you don't have an existing hole, I imagine you'd have to drill one...
  8. #448
    Jul 2010
    Yeah current Antenna is built into the rear window...
    Going to try using that, but if it doesn't work, then i might have to look at other stuff...
    Would an antenna work if it was inside the boot etc? Or does it HAVE to be outside?
  9. #449
    Newbie wiraone's Avatar
    May 2010
    Malaysia
    Quote Originally Posted by craigbrass View Post
    I am looking into being able to offer the following :-
    - A USB A to B cable with ferrites.
    - A 3.5mm to 3.5mm cable with ferrites.
    - A Motorola to SMB cable.
    - Aerials (Glass Mount, Magnetic and Roof Replacement).
    I will update you on the situation shortly.
    Was about to order it last night but backing off after reading further that I may need to source the connector/new antenna from somewhere else. Appreciate if you could do the above. I'll need to agree with some of us here who voiced that the deterrence factor from us who're not living in US or UK/Europe is the shipping cost. If you could combine the radio + antenna/connector, that will really help us alot.
  10. #450
    Jun 2007
    Paris, France
    Thank you for your feedback. Those are all issues we are working on. A new build tomorrow / Tuesday should sort the majority of them.
    So, no news of the last week update?
    The current release is useless as the plugin always crash after 30 minutes.
Tags for this Thread
