Page 46 of 170 FirstFirst ... 36373839404142434445464748495051525354555696146 ... LastLast
Results 451 to 460 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #451
    Apr 2010
    I have been providing daily updates to 6 users of this module as I want the next build produced to be near final and very stable. We should have this build out in the next few days. Sorry for the delay but we want everything perfect!
  2. #452
    Mar 2008
    Australia
    For those of us that don't have a spare line in jack, do we have another option? Will one of those usb to line in converters work?
  3. #453
    Apr 2010
    Well a USB sound card would work anyway...
  4. #454
    Jun 2006
    It is possible to have it configured with a TI audio over usb interface but this is rather expensive. a better option is to have a cheap usb soundcard.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  5. #455
    MySQL Error
    Oct 2004
    i got a bunch of USB audio in devices
    i need to sell em
    tiny little suckers
    really simple, 3.5mm jack in, and a mini usb connector
    ...i only made 25, got < 15 left
    PM me...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #456
    Apr 2010
    I take it these just show up as a line in device under Windows? Do they work with XP, Vista and 7?
  7. #457
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mitchjs View Post
    i need to sell em
    tiny little suckers
    PM me...
    Are you coming to AFKFest again this year? I bet if you brought those you'd sell out there lol
    Live mp3Car Facebook Chat
  8. #458
    MySQL Error
    Oct 2004
    craig, yes line in, of course xp, vista, win7, (and mac)
    infact they work much better in vista/win7
    they just the TI PCM2900s, which annoyingly come on as a line/line out divice, at least in a REAL OS (Vista/win7) you can disable the LINE OUT side
    in xp, u cant disable it, you just wouldnt use it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #459
    Dec 2007
    Sydney Australia
    Quote Originally Posted by RevheadKev View Post
    A couple of us in AUS will shortly be getting an SMB-BNC cable with a BNC-motorola connector to test my standard roof-mounted amplified antenna and their standard fender-mounted extendible non-amplified antenna. This should let us know which antenna will or will not suit both FM and DAB+ reception here in AUS.
    IT WORKS!
    DAB+ is alive in AUS.
    Got the connector and cable this morning and tried them at lunch. Hooked up the module with the cable and connector to the car antenna and controlled the module from my notebook with earphones in the module socket to listen with.
    Initially had drop-outs when driving around because signal was jumpy and only upto about half-strength in the DAB+ display mode. Then I realised that because I had unplugged the head unit from the factory harness and not just the antenna cable, there was no 12V powering the antenna amp. This was very encouraging to have such a reasonable signal without the antenna signal powered.
    So I jumpered 12V from the ACC/IGN pin to the antenna pin on the stereo wiring harness and FULL SIGNAL for DAB+. Have not driven around with it yet like this but with the visual difference in signal strength as seen by the module I think it should be OK.
    Now just got to get it all connected to the CarPC.
    Interested to see how the old passive extendable rod antenna of our other "tester" works with this connection.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  10. #460
    Apr 2010
    Nice one Kevin. Can you post a full review for us to use on our site once you have been driving about a bit please?
Tags for this Thread
