Page 47 of 168 FirstFirst ... 37383940414243444546474849505152535455565797147 ... LastLast
Results 461 to 470 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #461
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    Nice Radio you got there!
    Now I have a few questions, excuse me if I have missed the answer in this "short" thread
    First, can anyone tell me or show me a video of the FM reception? I have tried both Silabs and ADS but neither of them have worked good enough so that they would have been usable.
    Secondly, I looked both here, your website and DC for a RR plugin but couldnīt find one, or the it was just me not understanding... Could you please advise me in the correct direction, please?
    I will gladly order this product IF I can get it working in RR without bigger problems. Having to order a second soundcard is not a problem (using 5.1 sound out rear and front panel MIC for phone)
    Thank you!
  2. #462
    Apr 2010
    FM reception is as good as car head units. There are a couple of posts confirming this earlier on in this thread.
    You need to contact Mitch here on the forum for the RR plugin as he has been developing this. CF and standalone Windows plugins are available at http://www.craigbrass.net/ultimate_radio.zip with near final builds being released this week.
  3. #463
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    That's really good to hear Kev.
    Hopefully my radio is here soon and I can test it with an extendable mast antenna.
    Will post some info when it gets here.
    Cheers, Tom.
  4. #464
    Aug 2005
    Iceland
    Quote Originally Posted by tom_rosenback View Post
    Thank you!
    About the FM reception, it is better without antenna conected than on HQCT with antenna connected. I have not tried it in the "field" yet but first tests are looking very good.
    About the plugin. It is my understanding that with the next update of RideRunner the plugin will be included in the update
    One question to Craig. Is it ok to use USB 1.1 cable with the unit or do I have to use USB 2.0 cable?
    2005 VW Passat FSI 2.0
    Iceland
  5. #465
    Oct 2006
    Finland
    Thx craigbass, soyfish and Roadwarrior for you answers. I must place an order now then
  6. #466
    Apr 2010
    Roadwarrior: USB 1.1 should be fine. It only runs at 12mbps akaik anyway...
  7. #467
    Dec 2007
    Sydney Australia
    Quote Originally Posted by RevheadKev View Post
    So I jumpered 12V from the ACC/IGN pin to the antenna pin on the stereo wiring harness and FULL SIGNAL for DAB+. Have not driven around with it yet like this but with the visual difference in signal strength as seen by the module I think it should be OK.
    Well it seems like the antenna/cable matching is not quite right.
    Standing still in one place had the full signal but while driving arouns there were fluctuations and an occasional dropout. Signal was better up on the ridges rather than along the coast amoungst the apartment blocks. but then even FM has its "fuzzy" areas there too on a standard headunit.
    With some further research it seems the antennas with separate DAB and FM cables have the FM at 75 Ohms and the DAB at 50 Ohms so I am thinking them maybe it is an impedence mismatch causing signal degredation. This makes me think a standard RF combiner unit won't do any better. So now it is off to find a 75 Ohm -> 50 Ohm Balun and try that.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  8. #468
    Jun 2006
    kev, what antenna are you using?
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  9. #469
    Dec 2007
    Sydney Australia
    I have the factory-fitted amplified "bee sting" antenna for AM/FM reception with the Motorola plug on the lead.
  10. #470
    Newbie Asterix1965's Avatar
    Jan 2007
    Hello craigbrass
    I finally got cable for the antenna.
    But now I have a problem with the installation of radio with the drivers you provided.
    I state that I am in my CarPC has the steering wheel with adapter ibus / USB Resler.
    Just connect the radio and as mentioned you install the drivers provided once I notice that restarting the ibus adapter no longer works and in device manager I find the question mark is on the radio device that ibus adapter.
    I therefore fail to have both devices simultaneously lit ..... there is a solution ..... or am I mistaken something?
    Thanks for your answer
Tags for this Thread
