Page 48 of 168 FirstFirst ... 38394041424344454647484950515253545556575898148 ... LastLast
Results 471 to 480 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #471
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The iBus and this DAB radio both use the FTDI drivers, so maybe there is a conflict.
    There might be setting in the driver properties that can be changed
  2. #472
    Newbie Asterix1965's Avatar
    Jan 2007
    thanks for the reply.
    What should I change the properties of the drivers?
    What settings should I do?
  3. #473
    Feb 2007
    Macclesfield, UK
    Quote Originally Posted by Asterix1965 View Post
    Hello craigbrass
    Just connect the radio and as mentioned you install the drivers provided once I notice that restarting the ibus adapter no longer works and in device manager I find the question mark is on the radio device that ibus adapter.
    I therefore fail to have both devices simultaneously lit ..... there is a solution ..... or am I mistaken something?
    Did you plug-out the ibus adapter and put it into another USB port? This will change the COM Port number assigned to it.
    Andy
    Andy Whittaker
    Macclesfield, UK
  4. #474
    Jan 2007
    As soon as I have time I try to remove the ibus adapter and attach it to another USB port so let's see what happens
    thanks
  5. #475
    Jun 2006
    Quote Originally Posted by RevheadKev View Post
    I have the factory-fitted amplified "bee sting" antenna for AM/FM reception with the Motorola plug on the lead.
    kev, this won't work. that amplifier will have a band pass filter on it, which will attenuate the dab frequencies which are 175Mhz+. I think you might need a combined dab/fm/am antenna.
    i'm amazed you are actually picking any dab up!
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  6. #476
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No idea, just guessing in the dark at the moment. Will need to have a look on a PC I have a radio connected to. Not today though
    Quote Originally Posted by AndyWhittaker View Post
    Andy
    thanks
    What AW meant was, that if you have already changed the USB port the resler was connected to you will have to change the port number in the software you are using with the iBus.
  7. #477
    MySQL Error
    Oct 2004
    just download the NEWEST FTDI drivers, and pick a device and install using these new drivers
    it will overwrite any common files... and everything should work fine
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #478
    Jan 2007
    I already use the newer drivers to install DAB radio, so I should overwrite the ones used to install the adapter ibus?
  9. #479
    MySQL Error
    Oct 2004
    you should be able to unplg, replug the ibus...and all should be fine
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #480
    Newbie cockie55's Avatar
    Jan 2007
    Australia
    Quote Originally Posted by blade828 View Post
    For those of us that don't have a spare line in jack, do we have another option? Will one of those usb to line in converters work?
    Craig will "CD in" work????
    Landrover CF 3.1 Commell LV677 2GhzCore2Duo 4GDDR2 Military 80G SATA & SS Cartnetix P2140 & P5V Voom2 81/2" 16:9 5.1 3XAmps SOHO H/F Mini-PCI Wireless & 3G Wireless B'band Mini-PCI GPS - Destinator/OziExplorer HQCTi DAB+ SATA DVD Remote Cams TV UHF Radio
Tags for this Thread
