You can try it but I am not sure.Craig will "CD in" work????
Asterix1965: I had a customer by email having this problem and they told me the following worked: Unplug both devices and restart the computer. Run the FTDI driver cleanup tool they provide in the site. Restart again. Plug the radio in and install the latest FTDI drivers. Restart. Plug in the other device and use the same driver if requested. Restart. It should all work fine then. If not, make sure both are using a seporate port. You can change this in Advanced options.
VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
Build 90% Apps 50% Install 10%
Hi Craig,
Picked my radio up from the post office today, looks like it is all in one piece. It will be a while before I can test with my car antenna, but I will let you know how it goes.
Thanks, Tom.
you could use the mic in but it might clip.
some motherboards allow you to turn the mic amplification off. in which case the line level input would work.
The epitome of Function over form and is probably the best Car PC in Europe.
Visit my Homepage
I have tried 3 Microphone ports (home computer, office computer and laptop) with this and couldn't get any of them to work nor could I find the amplification off feature. Must be rare!
In Windows XP:
1. Double click speaker icon in tray
2. Open menu File
3. Check Advanced Controls
4. Click Advanced button under the audio line you want to configure, eg. MIC IN
5. Now you should see Microphone boost and a checkbox next to it.
More or less the same in Win7/Vista
Using Win7 and don't have those options...
Looks like I have that option on my laptop but not the other 2. Strange...
