Been concentrating on the rest of the setup while I see what happens with your antenna and looking for a DAB/FM antenna with only 1 cable or a cheap 75/50 Ohm impedence matcher to test or trying to workout if I can replace the antenna amp with one that has no bandpass filter. I got the module and know it works so now only have to get the antenna and the rest of the carpc working![]()
LinkBack URL
About LinkBacks
Will give you an review when arrived.
and then I mounted the PCB on a plastic risers that i got from my local shop to the metal plate. Best thing to do is use special drill to drill the holes (high speed) and i did it in few steps. Started with 1mm i think and ended in 4mm with two or three drill sizes in between. The last step I did with ordinary Dewalt drill. But do this on your own risk
