Page 53 of 170 FirstFirst ... 3434445464748495051525354555657585960616263103153 ... LastLast
Results 521 to 530 of 1694
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #521
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    Quote Originally Posted by nrgizerbunny View Post
    okay the outer part of the connector screws to the braided bit of the cable - this is ground.
    the inner part screws to the centre conductor
    Thanks, I thought so I just wanted to confirm before I put it all back together Will have some more pics / results soon.
  2. #522
    Mar 2010
    Why is this plugin taking so long? It seems like forever.
  3. #523
    Mar 2008
    Canberra, Australia
    Bit more of an update from me, went for about a 20 min drive to go for a ride on the mountain bike, and 20 min back again. Open roads, upto about 100kph, DAB+ and FM were perfect the whole way
    I tested DAB+ on the way there, and FM on the way home. Going through a tunnel that was about 200m long the FM crackled a little bit, but it was negligible. I didn't have the DAB+ running through the tunnel on the outward journey.
    Only problem seems to be that I have a bit of noise creeping into the system somewhere. I think it is from power cables for the computer or amp, it was present even when I put the radio into standby via the DAB_Master.exe. I have a feeling it's because I am using a normal household 3.5mm stereo cable. Has anyone heard of / used an automotive standard shielded 3.5mm cable?
    So far I am very happy little more tweaking to do, but it seems to be a goer here in Aus, especially as we are on half Tx. Big thanks to Kev, Craig, nrgizerbunny and everyone who has helped with this unit.
    Craig - Some suggestions as I assume you would like feedback. I understand that putting it in a nice shiny box would probably jack the price up a bit, but I think it would be well worth it for perhaps a v2 release. Failing that, some pre-drilled holes to drop it onto some risers would be good. I saw some in the middle of the PCB, but they are a bit tricky to get to. Sort of on the same line is the USB connector. It looks like its really only attached to the board with the terminals / connectors it uses so without the metal surround of the connector being against a case/bulkhead it can be a bit flimsy. Especially with that USB-B connector or what ever it is, it needs a bit of force.
    Cheers, Tom.
  4. #524
    Jun 2006
    soyfish,
    I'm glad the system works, I hope it lives up to your expectations.
    With regards to noise, yes this can be a problem and is usually down to the quality of stereo cable and connectors that are used. I use switchcraft connectors and 6.3mm diameter bandridge cable that is double screened. Given the nature of car pc power supplies it is inevitable that there will be high frequency noise all over.
    I would recommend the double screened cable and see how you go.
    nrg
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  5. #525
    Jul 2010
    I hope mine arrives soon.. looking forward to getting this all together
    Though it seems i'll still be waiting on aerial info, and the plug in/software..
  6. #526
    Mar 2008
    Canberra, Australia
    Quote Originally Posted by Sledge1 View Post
    Sledge, you have a soarer yeah? Not sure what the antenna setup on them was, but I remember that they seem to have pretty complex and integrated systems, so you might be best just to spring for one of the dedicated antennas from the UK or something ...
  7. #527
    Dec 2007
    Sydney Australia
    Quote Originally Posted by soyfish View Post
    Well done Tom.
    Seems the old non-amplified extendable-rod antennas could be an easy substitute to get decent DAB+ reception until someone finds a single cable version of an FM/DAB antenna.
    Glad I could help.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  8. #528
    Apr 2010
    Hey all, anyone know how to program these directly? I've coded my own frontend for my carpc in .NET and need to create a plugin for it so I can control this radio.
    Contact me directly via the contact form on http://www.coolapplab.com after you have made a purchase of at least 1 unit and I will send you the documentation.
    Hey Craig do you plan to release a Windows 7 Media Centre plug in for this? I know here in Australia theres a whole community waiting for DAB+ for there media centres
    Added to my notes and I will look into it.
    All being looked into.
    Update will be released tonight. You will see with the changes we have made why it took so long.
  9. #529
    Jul 2007
    Australia
    Quote Originally Posted by craigbrass View Post
    Awesome looking forward to it
  10. #530
    Jul 2010
    Yeah it's a soarer.. the antenna's are built into the rear windscreen or something..
Tags for this Thread
