On windows7 navigate to:
c:\ProgramData\Centrafuse\Centrafuse Auto\%USERNAME%
delete the username folder. Once you restart Centrafuse, it will startup like it's just been installed.
Andy
Printable View
I don't know if you are aware but the radio you currently have is one that I designed albeit originally for a venice 5, it was modified for a venice 7 and craig sells this. Unless you need the dab+, slave firmware is much easier to work with.
the new one will use the same module (venice 5 or 7) but will have different external components, the software will be the same.
Yeah need DAB+ here in Australia, also because the external components are different will this have an effect on the software? And will they improve the reception over your older model?
Also, im guessing the SPDIF will be in lou of the USB audio? I would prefer this as USB audio can be hit and miss at times
I'm interested. PM if I can help, I'm in the UK.
Edit; also if Mitch (or anyone other guru for that matter) is reading this, is there a way to use this and the silabs tuner together in RR? I noticed that there is only an option for one or the other in BlueZX3s config. The reason that I wish to use both is because I often use the Silabs to pick up RDSTA events while I'm listening to mp3s, so I would like it to still be able to do that while listening to a Venice7 device. Thanks.
I'll make a note and keep the board updated.
