Page 57 of 170 FirstFirst ... 7474849505152535455565758596061626364656667107157 ... LastLast
Results 561 to 570 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #561
    Aug 2009
    UK
    Quote Originally Posted by mitchjs View Post
    NO, not unless u wrote a plugin to do it
    I thought you might say that!
    What I was thinking that I could maybe do is keep running the Silabs in RR and embed the standalone app for the DAB into RR. Then using the "RADIOMUTE;ON" and "RADIOMUTE;OFF" commands I should be able to integrate it so that it the sound from the two doesn't overlap. Feasible? I guess I'll find out soon enough.
    BTW, in the text file of new radio commands it has the command listed as "RADIOMUTE;OF" which I'm assuming is a typo?
  2. #562
    Apr 2010
    Ok guys. Sorry for the delay. Updated standalone plugin to fix the C++ redistributable error and to make it work like our Centrafuse plugin is now at http://www.craigbrass.net/standalone.zip
    It is obviously still in need of a decent skin but this will come later.
    Centrafuse plugin hasn't been updated since the other day and is still at http://www.craigbrass.net/centrafuse.zip
    I am planning an update to the Centrafuse plugin tomorrow to fix a hibernation bug and to slightly change the way audio is done to fix a "buzz" some people hear in the background.
    Would appreciate people giving this a good test and reporting any bugs here.
  3. #563
    Aug 2009
    UK
    Does the standalone have this hibernation problem?
  4. #564
    Apr 2010
    It shouldn't as that is Centrafuse specific but I haven't tested it so can't say for sure. Will add to my notes for checking tomorrow.
  5. #565
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    Hi Craig,
    Haven't had a chance to do much more troubleshooting to get the plugin visible in CF on my carpc, but I thought of another question.
    As I mentioned, it worked fine on my home PC (Windows 7 64bit), but following the same process on the carpc (XP, 32bit) didn't work. Could that be having any influence, or would W7 just be running it as 32bit anyway?
    Thanks again, Tom.
  6. #566
    Dec 2007
    Sydney Australia
    Besides 32-bit and 64-bit, there are other incompatabilities between Windows XP and 7.
    Hopefully Craig's developers are making everything for XP which I think is the majority of the userbase (but I could be proven wrong on this view).
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  7. #567
    Apr 2010
    We develop on an XP system but I test on a 32 bit Win 7 Car PC and also on my desktop 64 bit Win 7 installation so it gets a good test. All works fine...
  8. #568
    Dec 2007
    Sydney Australia
    Quote Originally Posted by craigbrass View Post
    Dave: http://www.dabonwheels.co.uk/Bosch_B...ar_aerial.html is the aerial I use and with the latest design, it works well with both DAB and FM in my car.
    Craig,
    Do you only connect the DAB cable from the antenna to the module to receive both DAB and FM ?
  9. #569
    Apr 2010
    Well the problem is that I have not found an off the shelf aerial / antenna that combines (multiplexes) the signal down one cable - they all use separate cables. This is a problem as the Venice module has 1 input. As such, you have to manually switch over when you want to move between FM and DAB. I personally build a simple board with a switch on to move between but we are working on a multiplexer board that will combine the signals. It should be available as an addon shortly.
  10. #570
    May 2005
    Stockholm
    I have installed my radio tuner in the car and run it for a couple of days. I only had the original active window antenn for my BMW E39T that was not so good so I decided to install a new FM antenn on the roof on the car. Then I cut an old FM antenn conector cable and solider it directly to the SMF(B) connector.
    It's working good and I can receive both FM, DAB and DAB+ channels. I haven't driven any longer distance yet but so far it is no problem on either radio stations during driving.
    I have a question when it comes to DAB/DAB+ radio, is it normal to have some signal errors when driving? When I'm standing still I have 0 in lost bytes but when I drive I have between 0 to up to 20 bits lost in the info window. I don't hear this lost bytes so it is no problem. Just wonder if it's normal or not.
    The FM receiption is better than my original Head unit had with the original antenna. But I guess they would be quite the same if I would try to connect my HU to my new antenn mounted in the roof.
    I have only run into two minor problems. For the moment when I start my PC, RideRunner is loaded but the venice7 module failing to load. I have to exit riderunner and start it again. I guess this has something to do with the usb/serial software is not loaded fast enough in the startup and I have to delay the startup of Riderunner some seconds in some way to get it to work.
    The second problem is that I have very smal amount of disturbance. This is hardly notice when I have the volume on the venice7 module on maximum. But if I lower it to half I can hear it. This is something to do with some ground loops or something from the antenn ground. I will have to trouble shoot my ground. When I remove the connector between my soundcard and the radio modul it stops.
    I can realy recomend this radio module. I'm very happy with the result in my car. The only thing I missing would be sound over the usb module so I didn't have to trouble shoot my ground/earth problem.
Tags for this Thread
