Page 64 of 170 FirstFirst ... 14545556575859606162636465666768697071727374114164 ... LastLast
Results 631 to 640 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #631
    Aug 2009
    UK
    Quote Originally Posted by soyfish View Post
    where do I find the signal / packet loss stats that people want to know about?
    Toggle through the display and you'll see it 'signal error'. Generally it stays low but on my daily commute it hits 13 or 14 very briefly. You wouldn't know it though, there's no discernable difference in audio.
    What are everyone's thoughts on sound quality? There's no doubt that it is clear and crisp but I find it has a significant lack of bass. I don't know if that is related to the fact that it is connected via line in, or maybe because of my sound card.
  2. #632
    Newbie Huss's Avatar
    Dec 2007
    Just like to say hi to all, this all sounds very intresting dab at last need a new radio as my DMHD-1000 gave up few weeks ago on my spare one now, the warranty from www.mo-co-so.com on this item sucks as i have sent them 3 emails with no answer o well we`l see.
  3. #633
    Jun 2010
    Quote Originally Posted by Wolvers View Post
    Have changed the line out capacitors to 220uF, it seems to have more bass now. It is connected to the line in of a car radio.
    Would like to connect an additional DAC (Wolfson), but the firmware has not enabled the I2S output (I have heard).
  4. #634
    Jun 2006
    the bit rate on dab is worse than FM. Provided you have good reception on both FM will sound better. Frontier Silicon recommend 1uF - 10uF on the audio, I would have thought 220uF might dampen the noise and even distort it.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  5. #635
    Jun 2010
    The bit rate on DAB is 192 kBit/s on some channels, thats not bad !
    With my old Radioscape module (RIP) the sound was wonderful (with the mentioned Wolfson DAC). I do not say that the sound is bad with the Venice, but it has a reason they have designed a I2S interface for an external DAC.
    I think the sound depends also on the line in input resistance and the level needed.
    If someone has a low level line in, the sound might be better.
  6. #636
    MySQL Error
    Oct 2004
    220uf it too big...
    1uf - 10uf is typical on any audio output,
    i have seen some 33uf
    but never anything that big, it will affect sound quality
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #637
    Jul 2010
    Salut Craig - une estimation du moment où le plugin mise à jour des FC seront disponibles ?
    seule raison que je demande, c'est que je veux essayer une nouvelle version pour voir si je peux le faire fonctionner dans les FC . Qui sait , les fichiers recombobulated pourrait faire une différence . Si cela va être un moyen hors tension, puis je vais essayer de passer à windows7 sur le carPC afin que je puisse obtenir le retour ordinateur dans la voiture et donner des résultats vers les lecteurs avec mon antenne.
    En parlant de gents , où puis-je trouver le rapport signal / stats perte de paquets que les gens veulent connaître?
    Hello everyone,
    For Windows XP, the plugin does not work without net framework 3.5, installed it and it works under cf3.1
  8. #638
    Jul 2010
    Hi Craig - any estimate on when the updated CF plugin will be available?
    Only reason I ask is that I want to try a new version to see if I can get it to work in CF. Who knows, recombobulated files might make a difference. If it is going to be a way off then I will try upgrading to windows7 on the carPC so I can get the puter back in the car and give some results back to the readers with my antenna.
    Speaking of which gents, where do I find the signal / packet loss stats that people want to know about?
    Hello everyone,
  9. #639
    May 2009
    Quote Originally Posted by peter_f View Post
    Its the old-school inefficient codec used by DAB that is the issue. DAB uses the MP2 audio codec. Subjectively, a 192K DAB stream will be similar quality wise to a ~96K MP3 stream or a 64K AAC stream. Alot of the stuff in the UK is now at 128K or below which is simply not enough for MP2 to offer even 'FM Quality' audio
    DAB+ allows the use of the AAC+ codec (among others) and should offer superior quality while using less bandwidth. We should eventually get DAB+ in the UK - and at least the V7 on these modules is DAB+ ready.
    Nigel
  10. #640
    Jun 2010
    Quote Originally Posted by mitchjs View Post
    ... it will affect sound quality
    It should ;-)
    We need more basses and higher output level :-)
Tags for this Thread
