Page 65 of 170 FirstFirst ... 15555657585960616263646566676869707172737475115165 ... LastLast
Results 641 to 650 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #641
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    Quote Originally Posted by arachnidia View Post
    Hello everyone,
    For Windows XP, the plugin does not work without net framework 3.5, installed it and it works under cf3.1
    Thanks very much arachnidia! I have my plugin working - will do some more testing.
    Craig - might be worth documenting? Maybe a "pre-requisite" section that goes out with the purchase email?
  2. #642
    Aug 2009
    UK
    Quote Originally Posted by veletron View Post
    Its the old-school inefficient codec used by DAB that is the issue. DAB uses the MP2 audio codec. Subjectively, a 192K DAB stream will be similar quality wise to a ~96K MP3 stream or a 64K AAC stream. Alot of the stuff in the UK is now at 128K or below which is simply not enough for MP2 to offer even 'FM Quality' audio
    That interesting, thanks for the info. It's not a low quality sound as such, just that it has no depth/bass at all.
    Quote Originally Posted by peter_f View Post
    Have changed the line out capacitors to 220uF, it seems to have more bass now. It is connected to the line in of a car radio.
    Would like to connect an additional DAC (Wolfson), but the firmware has not enabled the I2S output (I have heard).
    I'm not sure that I want to be modifying my unit.....yet. Is it possible have an additional one in-line, as an adapter, to test? That might be within the realms of my talents, just.
    I also have a lot of interference from the DAB module that needs sorting. I'm afraid that this isn't the 'Ultimate' DAB/FM radio yet.
  3. #643
    Jun 2006
    it is possible you are picking up noise through the power supply. All of the radio pcbs I built had matched filters so each filter was a matched pair of capacitors and inductor. In case you were not aware the tolerance on capacitors is typically +/- 10% and that can have a big influence if the filter set is unmatched.
    I do not know if the ones craig distributes have matched filters or not.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  4. #644
    Aug 2009
    UK
    If Craig could confirm that then please?
    Just to be clear, when I say interference I'm talking about a high pitched noise from the ignition and alternator whine which I don't get from the Silabs (or the CarPC at all in fact).
  5. #645
  6. #646
    MySQL Error
    Oct 2004
    dont fight the noise... you prob wont win
    use a HQ ground loop isolator
    even for this a moderate qual one will do, for this...
    the loop is prob from usb ground to the soundcard ground
    (soundcards not made to be in a car)
    and remember, the noise is flowing on all ground
    it just entereds the audio, because of single ended designs of
    of the input on the soundcard, also can get right into audio cable(even shielded) cause
    alternator noise is low freq, shields due little to keep that out...
    like
    http://cgi.ebay.com/Ground-Loop-Isol...efaultDomain_0
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #647
    Aug 2009
    UK
    It's very possible that it's a ground loop problem, odd though that it's only an issue with the DAB unit. The Silabs is connected to the same aerial...............but the DAB is connected to the line-in of the sound card................
    Then again, it's advertised as 'tweaked for the Car PC enviroment to avoid interference' which suggests these bases are covered? Maybe not until it goes audio over USB like a Silabs?
    I'll do some investigation with grounding stuff..........and if I loose I might try an isolator.
  8. #648
    MySQL Error
    Oct 2004
    like i said, sound card... they not made for automotive use!!!
    audio over usb is completely differnt... noise anint getting into 1s and 0s
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #649
    Mar 2008
    Canberra, Australia
    On the issue of noise, increasing the volume of the unit via the DAB_Master certainly helped with mine and my mast antenna. I have a small amount of alternator whine now, and have one of those filters mentioned above on order to see if that resolves it.
  10. #650
    Jun 2006
    wolvers, there are a couple of things to check.
    If you've installed a new antenna (or even if its the existing) check the base of the antenna is grounded. Car bodies are galvanised and a bit of sandpaper under the locking nut could be enough to sort your problem out.
    also check your line in cable is double screened.
    Additionally the radios I built have switchcraft connectors, you could try swapping the one on the board to that type but you need to check with craig for warranty and all that.
    finally if you get stuck, send it to me and i'll have a look (I am in the uK)
    Visit my Homepage
Tags for this Thread
