Page 75 of 168 FirstFirst ... 25656667686970717273747576777879808182838485125 ... LastLast
Results 741 to 750 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #741
    Apr 2010
    Ok guys ... here we go ... latest version is at http://www.craigbrass.net/centrafuse.zip
    Hibernate now works flawlessly and all other issues mentioned here should also be fixed.
    If you could let me know any bugs in the next 12 hours, I will get the developer onto them tomorrow and release a new build tomorrow evening.
  2. #742
    May 2009
    Hi Craig
    Are you sure that you uploaded the correct file? I am not noticing any differences between that one and the last version regarding the issues I was having.
    The DLL's in the root are:
    RadioController.DLL --> V0.0.15.0, filesize: 72,704
    UltimateRadio.DLL --> V3.0.505.1, filesize: 338,944
    I assume these are the new ones?
    For the record, in my quick test:
    - The radio still turns on and off randomly when I goto the plugin
    - The plugin is still setting the WAV volume on the mixer for my sound device to maximum (don't even need the DAB board plugged in to see this, the plugin does this everytime that CF is started so long as its in the plugins folder). I'll re-itterate that this has nothing to do with my setup, Andy W's V5 CF plugin did NOT do this, I cannot see why any other plugin would need to behave differently.
    Regards
    Nigel
  3. #743
    Jul 2010
    Quote Originally Posted by soyfish View Post
    +1 for awaiting the new plug-in.
    For some reason I have been getting the problem with the radio blasting at full volume as my PC boots. Only happened to me twice since I have had it installed.
    Rather painful at 5am I can tell you!
    Me as a maximum volume at boot the PC. With the subwoofer amplifier
    Quote Originally Posted by craigbrass View Post
    The ultimate version of radio is the same as I have already:
    RadioController.dll 0.0.15.0
    UltimateRadio.dll 3.0.505.1
  4. #744
    Apr 2010
    Yes, I am sure I uploaded the correct version. This fixes many issues including hibernation issues and the ability to use the sort feature to delete / rename / reorder the station list.
    With regards to the flickering issue, this will ONLY happen when you first launch Centrafuse after updating the plugin. It will flash a couple of times while checking the status of the radio. After that, it should not do it again. Are you finding this isn't the case?
    With regards to the volume, can you provide the exact reproduce steps? I can't replicate this.
  5. #745
    May 2009
    Hi Craig
    For me currently the radio is switching on and off for as long as I am in the plugins screen. It works fine with dabmaster.exe I will have to do a video or something.
    Regarding the maxing out of wav this can actually be heard while on the plugin config screen. If I enter that screen while playing music and select by source and dest audio I hear a sudden leap in audio volume.
    There may be another instance of this same issue from someone else further up in this thread (loud audio).
    Unfortunately with these two issues still present I have not gotten any further with testing.
    Will try and sort a video out tonight
    Nigel
  6. #746
    May 2009
    One other observation is that with your plugin I do get different options audio wise in the plugin compared to andys v5 plugin. I am also using a USB sound card due to build in audio in infill g4. Being rubbish
    Nigel
  7. #747
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    Quote Originally Posted by veletron View Post
    There may be another instance of this same issue from someone else further ip in this thread (loud audio).
    Nigel
    The volume issue I had was that when booting from scratch, as windows was starting (ie, showing just the background before CF would load) the radio would play (not sure which station, probably the last one selected) full blast. It happened in two short (4-5 second) blasts before the PC had booted fully and CF had loaded. This sounds different to Nigel's problem. It was a fair old shock when it happened though.
    I'm at a loss as to why this is happening and why it has only happened twice in the month or longer that I've had it in. I will try it with the new plugin and see what happens, however I will be waiting until I am out of my apartment carpark until I boot the PC, I think the neighbors are getting a bit shirty - and understandably! Come to think of it, I have added an Andrea SuperBeam and the USB sound card recently in an effort to set up bluetooth. Perhaps adding a new sound card means that something is being muted on startup or something? That said, I don't have the sound card plugged in at the moment, but I will check the device settings for everything. This hasn't happened before the new soundcard added, but hasn't happened everytime since either.
    Craig - any ideas on this? Also, is anyone else getting it? It's a pretty big bug for me but could be isolated to just me.
  8. #748
    MySQL Error
    Oct 2004
    one of the problems with this module is(when being used the way we use it), it will power up in the LAST state it was in!!!
    so if left on, and power is abruptly removed, when power is applied, it will be ON
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #749
    Apr 2010
    Try the latest build: http://www.craigbrass.net/centrafuse.zip
    Issues resolved :-
    - Sometimes radio would not be on when resuming from hibernation.
    - After resume, sometimes radio would switch to opposite mode to what it was in when it was sent to hibernation.
    - Crashing when resuming from hibernation.
    - Volume getting reset to 100%.
  10. #750
    Apr 2010
    We are now on the Centrafuse approved hardware list based on the build I posted earler which appears to solve most issues. See http://centrafuse.com/SupportedHardware.aspx
    Newsletter, Twitter + Facebook announcement and news post on their site should be going live tomorrow.
Tags for this Thread
