Page 78 of 170 FirstFirst ... 28686970717273747576777879808182838485868788128 ... LastLast
Results 771 to 780 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #771
    MySQL Error
    Oct 2004
    soyfish, says to me the tuner was left on when you shutdown
    for it to be ON when pc starts up!!
    (i cant say for sure if CB's plugin, propertlly turns off tuner, when CF exists)
    assuming, you are exiting CF... no idea what exactly you are doing
    also andy's plugin is for venice5
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #772
    Dec 2009
    craig, any idea of an ETA yet?
  3. #773
    Apr 2010
    I'll get as much of the bugs resolved tomorrow or Saturday for you guys with a bit of luck. Sorry for the delay.
    for this, if he isnt doing a wav capture, its just a simple mute / unmute of the mixer input (playback side)
    oh man, i just looked at the code... it is doing capture!!!
    prob unessassary, and it looks like its own vs CFs BASS engine
    VERY good reason for that. Centrafuse audio manager DOES NOT work correctly. We tried to get it working but it would not accept that people may wish to use something other than the default audio device for source / playback. Our custom code works much better.
    and i have a major issue with it storing data in HKLM!!!
    I'll have this looked into. It is so our standalone plugin and Centrafuse could share the station lists as the standalone allowed sorting where as CF didn't in the early days of the plugin.
  4. #774
    May 2009
    Hi Craig
    I have to say that andys plugin was working fine with a non default audio device using the code built into CF. Unfortunately, rolling your own solution is bound to break things on some platforms (and maybe fix things on others!)
    I'm almost embarrassed to ask this, but I assume that the checkbox 'use only default devices' in sound/audio under control panel was *not* checked during your testing!?
    Nigel
  5. #775
    Sep 2010
    Hi
    I bought an Ultimate DAB radio a few weeks ago, it was working well in centrafuse until last week. after i got my OBDii/elm327 working. I've updated the plug-in hoping that would solve the problem but it hadn't.
    the stand alone program works fine.
    I've gone through the settings and the com port is correct and no other plug-in/ centrafuse program is using the same com port. I'm at a bit of a loss
    any one have any idea whats going on?
    Redgy
  6. #776
    Aug 2005
    Iceland
    Quote Originally Posted by mitchjs View Post
    hehe, well its not the commands going out.... it should say "scanning...." and stop when it finds a signal...
    actually its a SEEK by my definition
    I think I found out what is bugging me. When for example sometimes when I turn my car off the power supply tells the computer to turn off but for some reason It dosent. Insted I get warning that the program is busy and it asks me to retry or switch to the other program (I think I remembering this right) Next time Riderunner starts again and I switch to radio and try for example to scan/seek the radio jumps only 1 or 2 steps. If I shut down RR and start Dab_master and let it reboot the radio the problems seems to disapear.
    Any idea mitchjs??
    Is this some kind of a hardware problem on my end or is some settings in RR that I might have wrong??
    2005 VW Passat FSI 2.0
    Iceland
  7. #777
    MySQL Error
    Oct 2004
    the shutdown sounds like an issue... what os?
    did u tweak shutdown times?
    got embedded programs running...
    you know what i say, USE CARWINGS
    if you rebooted and started rr, pressing the >> << should work the same at all times.. remember it has to be HELD, its so simple to review ur debug log, to see what happend when u pressed the << >>
    also, what is "reboot the radio"
    hold say the >> for 5 seconds... you sould see
    9/23/2010 8:39:19 PM: Leave Exec: False, radio_player_venice7m.skin, dabup;p, False
    9/23/2010 8:39:26 PM: Leave Exec: False, radio_player_venice7m.skin, dabup;r, False
    i held that for 26-19 = 7seconds
    and when i do it goes "scanning"....
    if u see a "dabup;r" sooner, your release is coming in
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #778
    Apr 2010
    I haven't tried it in a while but I am fairly sure it doesn't support an external line in device and even alternative speakers? Our code does.
    Correct.
  9. #779
    May 2009
    Hi Craig
    Any chance that a future build can have an option 'let CF control Audio sources' or 'Let plugin control audio sources'. That would likely solve my 'no audio' issue, and probably other, similar issues with USB audio devices. Additionally, I bet many (likely the majority) are only using the default speakers/line-in.
    Nigel
  10. #780
    Apr 2010
    Are you the only one having the no audio issue with the latest plugin from http://www.craigbrass.net/centrafuse.zip ? Can you hear *anything* when the plugin starts? Have you tried selecting other options in settings for output? Which sound card do you use?
    I'd be reluctant to use both pieces of code as our code does work rather well in all the tests I have done.
Tags for this Thread
