Page 83 of 168 FirstFirst ... 33737475767778798081828384858687888990919293133 ... LastLast
Results 821 to 830 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #821
    Jul 2010
    Quote Originally Posted by wiraone View Post
    I've just received my DAB module last week and managed to get it half working right now. When I said half working, it works with Centrafuse 3.1 but not all the time. I've downloaded I guess the latest plugin from craigbrass.net .. managed to get it working after setting the port speed manually to 115200 but:
    1) The station and status on the top are displayed doubled .. both on the left and on the right side.
    2) Sometime the plugin will flipping on & off .. and touching any buttons didn't have any effect and sometime this will causes me to restart the whole PC.
    3) Whatever favourite stations that I've saved seems to be gone when exiting Centrafuse.
    4) Sometime I lost control to the radio, exiting Centrafuse or even after restarting the PC, the radio will still kind of 'switched on' .. I need to use the radio.exe to reset it back.
    Now wondering if my long USB cable causes the problem with lost control on the module. Haven't really play around with the standalone player yet.
    Hi, have exactly same problems with it, my cable is about 2 metres long.
  2. #822
    Jun 2006
    I thought I would post some piccies of my latest effort.
    PCB on the left, poplulated PCB in the middle and the older board on the right
    Here's the spec
    1. Venice 5.1 DAB/DAB+ and FM
    2. Slave firmware, runs with AndyWhittaker's plugin or the Venice 5 on RoadRunner
    3. Audio over USB using a TI PCM2902 Chip or 3.5mm Jack
    4. Draws 456mA under full load, Approximately 520mA on plugin
    5. Only 52 x 45mm
    6. Extremely large ground plane so less interference and more sensitivity
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  3. #823
    Aug 2005
    Iceland
    Quote Originally Posted by nrgizerbunny View Post
    Here's the spec
    5. Only 52 x 45mm
    Me likey
    Looks like a professional board
    Few questions.
    1. Will this board work for Venice 7?
    2. Will this board be for sale anytime soon?
    3. Estemated cost of just the board?
    I am very intrested in this board so I will be watching closely in future updates
    2005 VW Passat FSI 2.0
    Iceland
  4. #824
    MySQL Error
    Oct 2004
    bunny, nice socks
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #825
    Low Bitrate SoulR's Avatar
    Aug 2007
    Nice work nrgizerbunny,
    It's great to see the innovation wheel is still turning on this one, watching with great interest.
  6. #826
    Jun 2008
    Perth, Western Australia
    Thats looking awesome nrgizerbunny!
    If you can get one that works with the venice 7's, and still supports USB audio, I'm down for one
    Reminds me, I need to pull apart this DAB+ radio I have at work, and see whether the module in it is removeable, and which unit it is. We can't pick up the DAB+ inside our office (Metal framing in the walls), so I'm going to replace it with a normal stereo running through our net connection, and take it home to pull to bits
  7. #827
    Jun 2006
    venice 5/5.1/7 are all pin compatible so you can just bolt in whichever module you like.
    the only difference is the software you use. for 5 and 5.1 its slave. for 7 its master
    Visit my Homepage
  8. #828
    Jun 2006
    Quote Originally Posted by Roadwarrior View Post
    Me likey
    Few questions.
    answers to your questions:
    1. Yes it will work. Just a question of bolting a venice 7 in. For Oz the 5.1 with slave firmware is better IMO.
    2. I don't do marketing or selling. If I was to sell this then I would get someone else to do it. I hate queueing at post offices and the such like, which is why I sold the original board to Craig. The other issue is I am totally pedantic about assembly and every board I built was frozen to minus 20 and heated to +40C to check for poor solder joints. It was also subjected to vibration, this is not a way to run a profitable business but my name means quite a lot to me.
    3. cost of board and bits is Approximately $25CDN. This is dependent on how many are ordered at any one time.
    Visit my Homepage
  9. #829
    Aug 2009
    UK
    Nice work bunny. Loving the white socks too BTW. ;o)
    I'm thinking that I'd quite like to test out a Venice5, what's the best model to rip one out of that's still readily available?
  10. #830
    Jun 2006
    sony xdrs55 is a bolt in. 30quid on ebay for a black one, or £20 if you can handle pink
    others will require flashing
    Visit my Homepage
Tags for this Thread
