Page 84 of 170 FirstFirst ... 34747576777879808182838485868788899091929394134 ... LastLast
Results 831 to 840 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #831
    Jun 2008
    Perth, Western Australia
    Well thats interesting...I just pulled apart my DAB+ radio that I have for home (OXX Digital Classic 600), and it uses a Venice 6 module?
    Haven't heard of that one, and the pin interface on the board is about twice the length of the ones in your pics nrgizerbunny.
    It appears to provide FM, DAB+, LAN and WiFi onto a single board? I know thats what the unit supports....but could be interesting!
    Would anyone have access to a datasheet on the Venice 6?
  2. #832
    Aug 2009
    UK
    http://www.frontier-silicon.com/prod...nice6.2_PB.pdf
    Not sure what use that would be for a CarPC though?
    Quote Originally Posted by nrgizerbunny View Post
    sony xdrs55 is a bolt in. 30quid on ebay for a black one, or 20 if you can handle pink
    others will require flashing
    Cheers. So the xdrs55 one will go straight in, no kissin, with the RR V5 plugin then?
  3. #833
    Jun 2008
    I think mine seems to be the 6.0 version, not the 6.2:
    http://www.frontier-silicon.com/prod...Venice6_PB.pdf
    I see it supports i2c and spdif audio, would that still have the same issues as the 5.1 and 7 modules where its turned off in the firmware?
    The other parts (wifi and the like) wouldn't be much use, but its definitely interesting to see what they can jam onto one little board!
  4. #834
    Dec 2007
    Sydney Australia
    Nice compact design nrgizerbunny, but I have one suggestion if I may ... I would like to see the board a little squarer so that you could align all the connectors (3.5, usb, aerial). This would make fitting into a box simpler I think because all the connectors would be flush with the cover if you understand what I am trying to explain.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  5. #835
    Jun 2006
    Hi Kev, I'm open to suggestions.
    The main issue was real estate under the signal lines of the FTDI chip. I seriously shrunk the caps to make it smaller and to get everything on the board.
    The footprint is essentially the same as the Venice 5/5.1 or 7. I can easily make it bigger but this costs marginally more and is essentially a downgrade.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  6. #836
    Jun 2010
    Brisbane, Australia
    ok, now I am frustrated.... trying to install the updated plugin in centrafuse 3.1 and it is not seeing it at all (the plugin that is) I have copied the ultimate radio folder into the plugins folder - what am I doing wrong???? I can't even get the old version back (not that I ever got it working anyway)
  7. #837
    Newbie wiraone's Avatar
    May 2010
    Malaysia
    Quote Originally Posted by Kitiara View Post
    What OS are you running on? If it is WinXP, you need a .NET 3.5, for Vista & Win7, you should be able to see the plugin.
  8. #838
    Apr 2010
    Will this board be for sale anytime soon?
    I have rights to the previous board and this board from nrgizerbunny as per an agreement we both signed. Although I will purchase these designs from him as well, a fully USB version won't be available for 4-5 months at least for a few reasons.
    nrgizerbunny: Just replied to your email. Not sure where the emails you mentioned went but I never got them.
    With regards to the users who have reported software problems, expect a new build to be out in the next few days that should fix them.
  9. #839
    Jun 2010
    Brisbane, Australia
    windows 7 ultimate 64. it could see anything so I installed .net 4, still can't see it.
    it's cursed I tell you, cursed!
    Look forward to the new version, hopefully will at least be visible
  10. #840
    Aug 2009
    UK
    So it's on the CF supported hardware list but the plugin still doesn't work properly? Poor show really seen as CF and the hardware aint free.
    RR boys got their free plugin working ages ago, and is rock solid.
Tags for this Thread
