Page 89 of 170 FirstFirst ... 39798081828384858687888990919293949596979899139 ... LastLast
Results 881 to 890 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #881
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by Chester View Post
    Guys, I am massively excited!!
    Has anyone in Australia picked up the October 2010 issue of Silicon Chip?
    There is a design in it for a DAB+ and FM tuner built using a Venice 7 chip!
    Even better.....it will be in part of a kit offered for sale by Jaycar Electronics in Australia in December, including a Venice 7 with slave firmware AND WORKING SPDIF AND I2C!!
    There aren't any prices as yet, but I have emailed Jaycar to see if they will be offering just the Venice 7 module on its own, but guys, this could be the part we are waiting for!
    Imagine! Not having to rip apart a radio, then try to fiddle around with replacing firmware! Imagine having pure, clean, digital audio straight to your carpc!
    Please tell me someone is dead keen on this!!!
    If anyone wants a copy of the article (It is for a full designed radio, with controller board and LCD and all that guff), let me know, I can grab a snappy of the pages and forward them on.
    Will let you guys know if Jaycar confirm that they will be offering the Venice 7, as I think they will deliver to most places too....
    *dribble*
    That's just awesome!!
    Great find, and looking forward to this
    If this can be used and attached to a daughterboard to drive power etc, wouldnt that be a lot cheaper?
    My board has SPDIF Optical and normal line in along with onboard CDROM audio connector as my previous Carpc MB didnt so this one has the lot, yet to add this into my sig but this time I went quad core too
    Lets hope jaycar end up stocking them, will go out and grab one as soon as it's released, at least this will not break the bank I hope, but way too big for the car in it's current SC offering
    New Car PC Build list in progress
  2. #882
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Hmm i think the kit from jaycar is allready out:
    http://www.jaycar.com.au/productView.asp?ID=AR1753&
    Blessed are the "cracked" for it is they who let in the light.
  3. #883
    Jun 2008
    Perth, Western Australia
    Thats not the kit Boelle, just a regular DAB+ radio like you would normally pick up on the high street.
    The Jaycar kit is supposed to be under cat number KC5491, which currently doesn't bring up a result.
    And if that is $199 for the radio fully made, then the kit should be a fair bit less, so I'm pretty confident.
  4. #884
    Oct 2008
    Odense, Denmark
    doh, it just looked like a kit, my fault
  5. #885
    Dec 2007
    Sydney Australia
    Quote Originally Posted by ibf View Post
    Chester is correct.
    A quick google would give you this http://www.siliconchip.com.au/cms/A_112141/article.html
    It clearly state that they are using the module in slave mode. The DsPIC is used to control the slave module. All you need to do is design a carrier board and create a plugin and you are pretty much set.
    I don't think this is exactly true.
    Have you read the entire first page ?
    They have the DsPIC as the interface between the IR control, LCD display board, manual pushbuttons and rotary encoder.
    Someone will still have to reverse-engineer the comms between the DsPIC and the Venice7 slave firmware to workout how to control it from a plugin and display the text and other available information. Not impossible but much more work than you think I expect.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  6. #886
    Oct 2008
    Odense, Denmark
    Do we have some that are VERY good with serial protocols and checksums?
    Please PM if you want to help figuring out the comms
  7. #887
    Jun 2008
    Maybe its worth checking with the guys who were trying to reverse engineer the alpine comms?
    Still haven't heard back from Jaycar, I'm going to give them a call this morning and see what I can find out.
  8. #888
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by RevheadKev View Post
    Yes, you will have to know how to control the venice 7 in order to write your own plugin. This is either done by getting hold of the documentation or reverse engineer it. It has been done on the venice 5 before, so someone will just have to do it for the venice 7 this time round.
  9. #889
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by boelle View Post
    Are you working on the venice 7 protocol already?
  10. #890
    Jun 2008
    If they have done it for the Venice 5, then it shouldnt be too hard for the Venice 7 would it? Frontier Silicon tout it as a straight drop in replacement for the Venice 5, which I know would mean that SOME of the code would be different (for new features etc), but I would think the main controlling functions would still be the same?
    Although I am not a software engineer by any stretch!!! :P
Tags for this Thread
