Originally Posted by
mzhussein
i received mine, fitted it to car PC, its good, but i think needs a bit of refining, definitely worth the wait tho...
the volume up/down control for the radio (not main) takes ages to work and causes allot of lag
FM is crisp and clear, so is DAB.
Switching from DAB to FM and visa versa is kinda slow (is this normal?)
Switching from one preset in FM to another is slow, but once you've done it and do it again within say 20 seconds its quick....
When in DAB mode i cant figure out how to switch between stations? is there any way to see a list of available stations?
Resumes nicely from hibernate, no audio issues reported yet, tunes all the FM stations I'm used to niceley....
Stand alone program doesn't work on CAR PC but does work on home PC, says something about side-by-side error.
the whole feel of the CF plug-in is a bit "lumpy" if that makes sense...
but overall kudos to you, its definitely worth it, and I'm sure once the bugs are ironed out it should be an ideal solution...
worth noting i was able to just "plug and go" with no faffing around, which is not normal for CAR PC additions.
