Page 94 of 168 FirstFirst ... 4484858687888990919293949596979899100101102103104144 ... LastLast
Results 931 to 940 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #931
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by mzhussein View Post
    i received mine, fitted it to car PC, its good, but i think needs a bit of refining, definitely worth the wait tho...
    the volume up/down control for the radio (not main) takes ages to work and causes allot of lag
    FM is crisp and clear, so is DAB.
    Switching from DAB to FM and visa versa is kinda slow (is this normal?)
    Switching from one preset in FM to another is slow, but once you've done it and do it again within say 20 seconds its quick....
    When in DAB mode i cant figure out how to switch between stations? is there any way to see a list of available stations?
    Resumes nicely from hibernate, no audio issues reported yet, tunes all the FM stations I'm used to niceley....
    Stand alone program doesn't work on CAR PC but does work on home PC, says something about side-by-side error.
    the whole feel of the CF plug-in is a bit "lumpy" if that makes sense...
    but overall kudos to you, its definitely worth it, and I'm sure once the bugs are ironed out it should be an ideal solution...
    worth noting i was able to just "plug and go" with no faffing around, which is not normal for CAR PC additions.
    It would be lumpy no matter how great the plug in is. Its the nature of the firmware, it is just too limited and being forced to work beyond it. It was designed as a clock or kitchen radio with 2x16 LCD and buttons to press. Dont be too surprise if it accidentally come up with alarm clock menu, snooze and timer or something. I dont know how well craig team can patch it all up but thats just the way it is. It is no top secret whats going on in that radio.
  2. #932
    Apr 2010
    It doesn't do anything like that. Our coding makes sure of it.
    have we sorted out a suitable aerial solution for use in australia at all?
    During purchase of our unit from http://www.coolapplab.com/ultimate_c...ona/index.html you can add a good quality roof replacement, glass mount or magnetic mount. Personally I prefer the roof replacement and is what I use.
  3. #933
    Jul 2010
    Quote Originally Posted by craigbrass View Post
    Already got the unit from you
    will check what you've added..
  4. #934
    Apr 2006
    Sydney, Australia
    Well I've ordered mine now since the $ is going down and I do hope I get a new version (*hint)(*hint) without to many hiccups and delays (*hint)(*hint)
    Feel free to throw in a roof mount antenna, since this thing has cost me an Kidney
    REF#Craig Brass Systems: Order #703
    Happy to support the mp3car community, so not going to bother with the Silicon Chip path
    Cheers
    Kosti
  5. #935
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by ibf View Post
    Info from digital.co.uk its a confirmed venice 7 module
    £24 @ Tesco
    http://direct.tesco.com/q/R.208-0202.aspx
    and possible tons more of different make and model floating about for that price.
    Is anyone coming to Sydney for a holiday, sadly this guys doesnt ship it outside the UK, and at that price, Id love to get one for the boat
    Anyone bought one, what are they like, cheap price as the cheapest ebay DAB+ radio for Sydney is like $70 buck
    New Car PC Build list in progress
  6. #936
    Jul 2010
    Quote Originally Posted by Sledge1 View Post
    Do those antenna's do both fm/DAB+ or is it only 1 or the other? what's the story with them?
  7. #937
    Apr 2010
    Contact us using http://www.coolapplab.com/contact_us/index.html and we should be able to create you a manual invoice for any additional items you want.
    Any orders that haven't gone out yet will get the new board. Will get some photos up shortly.
    Is it the entire radio you are wanting or just the chip? Maybe I should ship a load to you and you can eBay them
    The mag mount works okish with FM but perfect with DAB / DAB+. Glass mount is only good on DAB / DAB+. Replacement roof aerial is the best solution but has a socket for DAB and a socket for FM so you have to switch over. We are working on a multiplexer board to combine the signals which should be out next month.
  8. #938
    Aug 2009
    UK
    Quote Originally Posted by Kosti View Post
    I've bought two now, they're crap radios but they have V7s in them.
  9. #939
    Apr 2010
    Just FYI guys - the Tesco radios don't have an SMB connector on. This either needs to be soldered on or just wire soldered directly on.
  10. #940
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by Wolvers View Post
    Are you planning on flashing them?
Tags for this Thread
