Page 97 of 170 FirstFirst ... 4787888990919293949596979899100101102103104105106107147 ... LastLast
Results 961 to 970 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #961
    Apr 2010
    The only thing with the Venice 7 is the sensitivity is marginally better on DAB and slightly more than marginal on FM.
    I personally have found it is more than marginal in my tests and the unit tends to work better with glass mount aerials as an added bonus.
    And just to clarify one other point. If you get the Venice 7 with generic slave firmware, it will also work with the Venice 5 slave software. It can be found in high end Sony DAB+ radios (like mini systems). Pure radios also use venice 7 but their firmware is not generic and seems to be more like master software - I'd steer clear of this.
    Incorrect. The slave firmware was TOTALLY rewritten between 5 and 7. It requires reverse engineering and plugins / standalone software built. Master firmware is pretty similar between both.
    Craig brass said 5.1 is no longer in production. It is not longer listed on frontier website either. Because of that, venice 7 is the way forward but who is going to hack it and share their work here?
    FS no longer sell the Venice 5 or 5.1 to radio manufacturers. Only available method of obtaining it is from existing radios.
    Im sorry for the misunderstanding. What I meant to say was write the plugin to operate the master module like a basic kitchen or clock radio. Obviously less the alarm function on the menu. Atleast we know this should work pretty solid rather than trying to emulate the slave function. If that make any sense?
    Possibly but its pretty basic. I'd much rather get a solid emulation as this is what my customers want according to various email communication (feature requests, etc).
  2. #962
    Aug 2009
    UK
    Quote Originally Posted by Roadwarrior View Post
    Like I said before and will say again there should be two seperate threads, one for those who want to go deep in hacking Venice and other thread for craigbrass and his support and discussions around the ready made product that he has including software.
    Well start one then.
    CB can start his own for his products and support, or use this one.
  3. #963
    Apr 2010
    I'll just keep posting in this one as I have posted in it so much already I think.
  4. #964
    Aug 2005
    Iceland
    One question to Mitch.
    Is it possible to change the color of the font in the RR plugin for the radio. It is now white-pinkish but I would like to be able to change it to blue.
    2005 VW Passat FSI 2.0
    Iceland
  5. #965
    Jun 2006
    Quote Originally Posted by craigbrass View Post
    Yep the firmware is different between 5 and 7. The serial commands in slave mode are the same, no rewriting of front end software is required. you can go to mediaMarkt buy a Sony CMT350, plug it into a board and it will work with venice 5 software.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  6. #966
    Apr 2010
    Interesting. I have tried a module from a Sony radio and it didn't work.
  7. #967
    ibf
    ibf is online now
    Oct 2010
    Which sony model did you try craig?
  8. #968
    Apr 2010
    Can't recall but it was one mentioned here earlier on I grabbed from Currys. Still have the unit at the office I think so will check in the morning. It wasn't using master firmware as it didn't respond to the commands or sending back the display so assuming it is slave. I tried it with the two standalone plugins and the CF plugin and it didn't work with those either so assuming what I was told about the firmware and command set having a total rewrite for slave being true.
  9. #969
    ibf
    ibf is online now
    Oct 2010
    Was it this one? Its a V7 inside capable of DAB+
  10. #970
    MySQL Error
    Oct 2004
    not today, it was a thought, but it passed
    i just added a option
    v7mtextcolor=
    the colors avail are from the known color enum
    http://msdn.microsoft.com/en-us/libr...nowncolor.aspx
    so...
    v7mtextcolor=blue
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
Tags for this Thread
