Page 99 of 170 FirstFirst ... 498990919293949596979899100101102103104105106107108109149 ... LastLast
Results 981 to 990 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #981
    Apr 2010
    It isn't something you can really tell looking at the photo I provided.
  2. #982
    Sep 2010
    Quote Originally Posted by Wolvers View Post
    I fixed this issue by impedance matching the aerial ground with the audio and usb grounds, the details of which are a few pages back. Others have cured the ground loop problem by using ferrited audio cables.
    I tried that. I used ferrite USB cables or added ferrites if they had none, same goes for audio cables.
    I ended up buying a USB isolator that isolates the power and ground wires from the pc.
    Nothing I tried worked. I have good clean grounds on everything but the second I put power to the charger the noise is there. If I disconnect the ground from the charger and just leave the postive connected the laptop still shows that it is charging.
    My problem is fixed but I thought I'd mention it for the sake of others who may come across the same problem.
  3. #983
    Aug 2009
    UK
    Was it intentionally blurry then?
  4. #984
    Jul 2007
    Australia
    I dont think theres a conspiracy here, i would suggest that C/B wouldnt post a picture at all if there was something to hide.
    But i am interested to here what N/Bunny meant by his comment though
  5. #985
    Jun 2006
    Quote Originally Posted by craigbrass View Post
    There are two SOT regulators at the top with a hf cap and a electrolytic buffering. there doesn't appear to be any LC filters (I could be wrong) so I'd say it was built on a bench and not with an alternator for a power supply.
    Just to add , I think the big cap in the top left is adjacent to the hf cap (this buffers the 5v), next is a 3.3v regulator with big cap and hf cap, and adjacent to that is the 1.2v regulator and big cap and hf cap.
    Please don't get me wrong, that layout is neat and efficient and I commend whoever designed it but I don't believe it was designed in a market that has dab or dab+, the reason is when the venice tunes to a weak signal (multiplex) its power rails fluctuate, if the caps/filtering aren't man enough, the radio will reset itself or start to go choppy, this is really evident on channel 11D.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  6. #986
    Apr 2010
    Nope. My phone just takes rubbish photos but it is the only thing I had to hand to take a photo with.
  7. #987
    Constant Bitrate HoSS's Avatar
    Dec 2004
    What i would prefer is that you ship me the new board (just the base board) in exchange for the old one, when its available.
    btw, i'm using latest version of the CF plugin.
    Forgot to add, if you want a refund, return the item and I will provide one. Perfectly happy to do that.
  8. #988
    ibf
    ibf is offline
    Oct 2010
    Lots of puzzle in this thread.
  9. #989
    Aug 2005
    Iceland
    Quote Originally Posted by mitchjs View Post
    not today, it was a thought, but it passed
    i just added a option
    v7mtextcolor=
    the colors avail are from the known color enum
    http://msdn.microsoft.com/en-us/libr...nowncolor.aspx
    so...
    v7mtextcolor=blue
    Exellent! Just one more request
    Is it possible to change the font type?
    Also is the color change done in rr.ini or somewhere else??
    With thanks for quick answers
    2005 VW Passat FSI 2.0
    Iceland
  10. #990
    MySQL Error
    Oct 2004
    oh gees, not at this point, character set is customized
    and cant simply use another font, or the glyphs wont match
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
Tags for this Thread
