Page 20 of 71 FirstFirst ... 10111213141516171819202122232425262728293070 ... LastLast
Results 191 to 200 of 709
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #191
    Nov 2010
    Hey Grumbel, I have been looking at your excellent research posted here: xbox360 chatpad, awsome backlit mini keyboard
    I was doing some more testing while implementing stuff, and I gathered the following additional information:
    1. The 0x00 command turns the caps lock light off (0x41, 0x00, 0x0000, 0x0002, 0x0000).
    2. The 0x01 command turns the green square light off (0x41, 0x00, 0x0001, 0x0002, 0x0000).
    3. The 0x02 command turns the orange circle light off.
    4. The 0x03 command turns the "people" light off.
    5. The 0x04 command seems to instantly turn the backlight off.
    6. I am not aware of a way to disable the backlight but still support keypresses. I can make the backlight turn off quickly (see above), but if I don't use the 0x001B command to enable backlight-on-keypress mode, then I don't seem to get character data at all. This might not be a big deal, but I've put the possibility of not having a backlight when keys are pressed as a possible future option/research area.
    7. The chatpad also cannot apparently support more than two buttons held down at a time, which is not a problem, just an observation presumably due to how it's wired internally.
    8. If more than two lights (caps, green, orange, people) need to be on at a time, the commands seem to not work if you send them too quickly. I put a sleep for 12 milliseconds (though of course Windows may actually wait longer than that for all I know) in between four light-on commands, and it seems to work lighting up all four lights. I'm not sure if there is a shortcut to turn off all multiple lights at once without sending the individual light-off commands, however.
    Just wanted to throw the info out there since I had been experimenting with it.
  2. #192
    Nov 2010
    Quote Originally Posted by lehnny View Post
    When I bought the chatpad I thought my days of reaching for the keyboard were over. Opening the package was a very exciting moment for me only to find out that it does not work. I've read the first page of this forum and then skipped to the last. From what I can see GAFBlizzard is close to making a driver that will allow us to use the chatpad as if it were a keyboard and I want in. I have no problem in paying for his hard work toward this goal. However, I’m on a fixed income and would very much prefer to donate for a finished product. My only concern is that if GAFBlizzard does manage to finish a working driver that it might not work for me because I use Xpadder to program keystrokes into my controller. I don’t think this should matter, but I also thought that the chatpad would work for my PC in the first place.
    XPadder doesn't require any special drivers, does it? If it's just a program, then you should be able to use my driver seamlessly to just give you all the extra buttons. Thanks for your patience and kind words. Also, I mean this in the kindest way possible -- keep the donation. I'm planning on sending any of the prize money that is not used for a kernel driver signing certificate or a wireless controller to charity anyway, and I've spent too much effort and money already to try to demand a payback. Plus it wouldn't be fair since I'm benefiting from the hard work of people like Grumbel.
  3. #193
    Nov 2010
    Quote Originally Posted by GAFBlizzard View Post
    You, my friend, are a god walking among men. Kudos & keep it up! When you do finish this, please let us know which charity you will be donating to and i'd be more than happy to throw a little bit more there way. You are giving so many people the gaming (and HTPC) experience they've longed for for years.
  4. #194
    Nov 2010
    I'm planning on requesting Child's Play (http://www.childsplaycharity.org/) since it is pretty well known, plus it's related to gaming and this is a game controller (even though it might be used for car PCs). :P
    I have a full key configuration file for the unmodified chatpad keys now. It seems to work great except for the shift key (I need to change something) and a rapid keypress issue, discussed at the bottom of this post. I will probably only add support for the "normal" punctuation symbols for now, and leave the special characters (such as orange + G, or orange + K) as features I may add after the initial public release and testing. If anyone has any special symbols shown on the chatpad that they REALLY need, let me know. Otherwise I'm holding off to save time. And what the heck is that orange + K symbol anyway?
    I have a request for help! If anyone has a chatpad and an XBox 360, can you try to press a button (like 'F') really quickly several times, and see if it types the same number of letters? It should be easy to hear it "click" say, 7 times. If you do this really fast, but hear the clicks, does the XBox 360 ever only print say, 5 letters? I want to make sure this is potentially a chatpad/controller quirk and not a problem with my driver/utility code.
  5. #195
    Dec 2010
    Clicks
    I'm hitting letters as rapid fire fast as I can, and I get the same number on the screen. I'm a little suprised. Also if I hold down a letter it repeats. I'm using a wireless 360 controller if that makes a difference. Thanks for the work, I'm real excited to watch this change how everyone uses media at home.
  6. #196
    Jul 2010
    GAFBlizzard, i suppose you have this link, perhaps there is nice info for you:
    http://nostalgium.com/forum/viewtopic.php?f=2&t=2
  7. #197
    Nov 2010
    Thanks for the check on rapid keypresses. I have an idea that will hopefully let me read the data more quickly. Key repeats are working with my setup, by the way (I think that was a benefit of using a virtual HID keyboard, since the Windows stuff is smart enough to do it automatically). Also, thanks for the link, MiYaGin.
    I have one more question for people in general, especially anyone who had special concerns about key mapping. Does anyone have a problem with me making the shift key, the orange key, the "people" key, and the green key unaffected by any modifiers that might be down? In other words, with all the other keys you can bind stuff like "1 + shift = F1", but I think it would be much simpler for me if the shift/orange/people/green keys were special cases. Making them special cases means that you would be able to use more than one modifier to affect OTHER keys, so you could theoretically bind "1 + orange + green + shift = F24" or something crazy like that.
    If you wanted, you could still bind the orange key itself to some other key, and not use any of the orange symbols labeled on the chatpad. I imagine most people would use the normal green/orange binds, however.
  8. #198
    Nov 2010
    I think that would be a great idea
  9. #199
    Jul 2010
    To whoever is managing the donations... Did mine go through? I sent another $15 around November 18 on top of my first, original donation.
  10. #200
    Nov 2010
    At least have it orange + green + any key = any shortcuts people want.
    I want the people Key for the Windows key as it helps and
    For the Orange + K key = Microsoft Point symbol.
    as I have a xbox 360 and a wired xbox 360 controller with Chatpad xD
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 10:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 05:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 06:18 PM
Tags for this Thread
