Page 30 of 71 FirstFirst ... 202122232425262728293031323334353637383940 ... LastLast
Results 291 to 300 of 709
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #291
    Dec 2010
    Someone should make a youtube vid when this is done, I wanna see this beautiful thing in action!
    Also, Merry Christmas!
  2. #292
    Nov 2010
    Quote Originally Posted by Chatcat View Post
    O Nooooo
    After banging my head against a wall, I have decided to go with a single INF file per operating system. In fact, I may just provide a different install executable for each operating system and be done with it.
  3. #293
    Jul 2010
    Whatever works best
  4. #294
    Dec 2010
    I too didn't know there was a difference in wired controller types ... and I was just about to go buy a 360 wireless controller
  5. #295
    Nov 2010
    Quote Originally Posted by revel911 View Post
    My current theory is that the difference was one of the reasons that one guy could use a wired controller and chatpad with the Mac driver, but another one could not. And that difference was also a red herring that prevented anyone from getting the chatpad messages to start. At least, such is my theory.
    At any rate, you SHOULD be able to use a 360 controller, though if you're only buying it for Windows you might as well get a made for Windows one unless it's cheaper not to.
    INF files are spawn of the devil, but I just finally got a multi-installer package wrapped up for Vista, I think, and I can NOW actually do a clean build to make the Windows 7 one.
    I had so much stuff to do today (non-chatpad stuff, getting ready for the trip, etc.) and haven't got much of it done, and then I was out for a while with a friend, but now I'm back for the evening. My flight was cancelled with no explanation, as far as I'm aware, so I am spending Christmas alone and going home on Monday. Looks like if anyone's reading the forum over the weekend, you'll get extra Christmas updates.
  6. #296
    Nov 2010
    that sucks that your flight was cancelled bummer, but keep up the good work.
  7. #297
    Nov 2010
    It's around 3:30 a.m. on a Christmas morning, and I traced down a memory problem I ran into right as I thought I had stuff built for uploading. :P Anyway, I just tested an install zip on Windows XP 32-bit, and it seems to work fine.
    Okay, it seems pretty much good to go now. It should support Windows XP, Windows Vista, and Windows 7, in both 32-bit and 64-bit variants. Read through the updated Getting Started notes for download links and install instructions:
    http://code.google.com/p/chatpad-sup...GettingStarted
    Let me know how it works for you! I still want to improve the install process slightly, make the change to hopefully fix 360 console controllers, and get source code uploading/tracking working with the site. There might be another update in a day or so.
  8. #298
    Sep 2010
    I believe this is due to the fact i have the xbox controller rather then a made for windows controller...but ill post this anyways, maybe u can find it helpful...
    XP 32 Says...
    Chatpad control utility version 0.1a started.
    Please wait...
    Control utility started.
    Opening chatpad filter driver.
    Successfully opened chatpad filter driver.
    Successfully connected to XBox 360 controller.
    Opening connection to virtual keyboard device.
    Successfully opened connection to virtual keyboard device.
    Successfully connected to the virtual keyboard device.
    Opening connection to virtual mouse device.
    Successfully opened connection to virtual mouse device.
    Successfully connected to the virtual mouse device.
    Microsoft initialization has been finished, so we can init the chatpad now.
    IOCTL failed, lastError == 31
    Successfully sent IOCTL. Bytes transferred: 2
    Control response data received: 0x01 0x00
    Control response data sent: 0x09 0x00
    Control response data received: 0x09 0x00
    Successfully sent IOCTL. Bytes transferred: 3
    Reading thread started for controls data.
    Reading thread started for chatpad data.
    Worker thread started for mouse data.
    IOCTL failed, lastError == 121
    Thread shutdown detected while in ControllerReadFunction.
    Thread shutdown detected while in ChatpadReadFunction.
    Reading thread for controls data has ended, with nStatus == 0
    Reading thread for chatpad data has ended, with nStatus == 0
    Worker threads successfully stopped.
    Closing connection to virtual keyboard device.
    Closing connection to virtual mouse device.
    Closing chatpad filter driver.
    Done. The exit status is -1.
    WIN7 32 says...
    "Failed to updated chatpad filter device driver: 0x000000002"
    I cant get it any further then that :/
    P.S. this is a netbook with an intel atom..not sure if that would make any difference though
    If there's anything else i can do or test to help out lemme know, otherwise ill just be patient, I'm sure u already got it all figured out ;D
  9. #299
    Nov 2010
    Quote Originally Posted by mutantrabbitjoe View Post
    I missed the WDF coinstaller in the Windows 7 files. No wonder that file size was small, grr. Let me fix it real quick. I'm not sure about your first results but I'll take a look at it again. *edit* A new Windows 7 download is up, and this time it's a more reasonable file size.
  10. #300
    Sep 2010
    Sweet, just tried running it again.
    this time it failed to update virtual keyboard device driver: 0x0000217
    lol.
    not sure what i did wrong <.< im sure i uninstalled the previous attempt tho. Anyone else got win 7 and can test this out? I may give it another try on my vista box as well, if i can get it booted up (dads gf smashed the holy hell out of it...no longer has a screen, dvd drive, and half the case is missing lol)
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 10:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 05:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 06:18 PM
Tags for this Thread
