cool, ill try that stuff out when i get sum time and post the outcome.
Merry xmas GAFu should take the day off tommorow lol :P
Thanks for all your help with this. I may try to install Windows 7 myself this weekend on a spare hard drive, since I've had the OS sitting around.
1. When you uninstalled the previous attempt, did you make sure to manually uninstall the HID keyboard, HID mouse, and chatpad keyboard/mouse devices in device manager? There should be a total of four things you right click and uninstall. If you did, and someone else has the same problem, then I'd say just wait until I get Windows 7 running myself since there's probably something silly I didn't know about Windows 7.
2. Regarding your XP 32 system, I'm really not sure it's your controller's fault. It looks like it's responding to data like I would expect. If you're still using the old driver, and you have a USB stick, could you maybe copy the latest official Microsoft driver to it, and make sure the chatpad driver is uninstalled, and then go through the install one more time? You can find the latest official driver here: http://www.microsoft.com/hardware/do...XP_SP2&lang=en NOTE: It looks like it only works on XP SP2 or later, so if you have a REALLY old XP machine it might not be supported.
3. If the above doesn't help, the last thing that would be helpful to me on the XP 32 system is for you to kill the chatpad control utility, unplug the 360 controller, and download DebugView: http://technet.microsoft.com/en-us/s...rnals/bb896647 It's a utility that can show debug output. Run it. Go to the capture menu and make sure everything is checked except for "Log Boot". Then, plug the controller in, wait for messages to stop updating, and run the chatpad utility until it crashes. Finally, use the File->Save As options to save a .LOG file, and email it to me (gtschemer, at gmail.com) so I can have a look in case the driver debug output gives any clues.
Good luck, and get some rest! I think it's about time for me to hit the sack. Merry Christmas everyone. I'm trying to get this working for you all!
GAFBlizzard: #1 you deserve the cash already (after providing source, ur the firstthanks a LOT.
in the keyboard/mouse inf, there's an error 'CopyFilterDriver' is not a valid inf section ON WINDOWS 7-64BIT, resulting in the 0xe0000217
this must be replaced with > CopyFunctionDriver, then its working
[gafblizzard inf code in keyboard]
; This was apparently a typo in the hidusbfx2 example. It should be CopyFilterDriver, not CopyFunctionDriver.
[CopyFilterDriver]
chatpad_keyboard_kmdf.sys
[/end gaffbliz code]
should become:
[new inf code in keyboard]
[CopyFunctionDriver]
[/end new code]
Well, i started setting up xpadder with my 360 controller, excited about the chatpad finally gonna work....then learn the game i play recently had a Hackshield update...no more xpadder or anything like that allowed...FUUUUUU...
T.T
Im worried these chatpad drivers n such will be blocked too T.T but o well...hate hackshield sumtimes..
GFblizzard: after changing the inf section as described earlier, i get the following output:
Chatpad control utility version 0.1a started.
Please wait...
Control utility started.
Opening chatpad filter driver.
Successfully opened chatpad filter driver.
Successfully connected to XBox 360 controller.
Opening connection to virtual keyboard device.
Successfully opened connection to virtual keyboard device.
Successfully connected to the virtual keyboard device.
Opening connection to virtual mouse device.
Successfully opened connection to virtual mouse device.
Successfully connected to the virtual mouse device.
Microsoft initialization has been finished, so we can init the chatpad now.
IOCTL failed, lastError == 31
Control response data received: 0x00 0x00
Error initializing chatpad.
Closing connection to virtual keyboard device.
Closing connection to virtual mouse device.
Closing chatpad filter driver.
Done. The exit status is -1.
windows 7 i386 failed to install keyboard
windows xp i386 install without any problems.
and im on my netbook using the chatpad, thanks GAF for everything xD
Don't worry, just wait and see. It just acts like an ordinary HID keyboard and mouse, and I'm hoping that won't cause any problems since it's not a cheat program.
Let me know if you get a chance to try the things I suggested!
Yay, looks like you're the first person who's been able to use it! The mouse sensitivity with the thumbsticks may not be perfect, so you might want to check the configuration file to adjust it.Do you remember what error you got on Windows 7? Was it 0x00000217, like mutantrabbitjoe got?
Hey, you're welcome to use another tool for the mouse part! As long as the controller still works and your tool still works I'm happy to hear it.If you haven't done it already, remember you can remap the people button to something like the Windows key, or a modifier to give you more hotkeys, since you're not using it for thumbstick mouse control.
Thanks for the Windows 7 info. Sounds like I just need to figure out what Windows 7 needs in the INF file that's special so I can get the virtual devices working. I should go ahead and install it later today.
*edit* If anyone has Windows 7 and tries it, it isn't working now from the reports above, but could you try something to help me out?
1. Delete (or make a backup if you want to keep) C:\Windows\INF\setupapi.dev.log
2. Make sure you have all of the HID-compliant keyboard/mouse and chatpad keyboard/mouse devices cleaned up from the last install attempt...sorry, I know I need to finish making that uninstall better.
3. Try the install again, until it fails, and then quit the install program.
4. Email me the newly generated C:\Windows\INF\setupapi.dev.log file. Feel free to look through it yourself to see what's in it. It should contain error information so I can figure out what's wrong with the INF installation.
I found the error in Win7
it needs to copy "chatpad_keyboard_kmdf.sys" and "chatpad_mouse_kmdf.sys" to
*:/Windows/System32/Drivers/
i did it manualy and it installed xD
