Page 33 of 71 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 321 to 330 of 709
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #321
    Dec 2010
    GAFBlizz: can i have a live chat with you on http://chat.mibbit.com > there are some issues i got with the pad, we might find solutions to them..
    (like driving signing ; )
  2. #322
    Dec 2010
    Only in the last attempt of below logging, it did turn on the light..
    but still no interaction, i dont see any updates when i press the buttons on my chatpad
    (want to mention, its 100% genuine MS hware im using, both controllers i got, wired/wireless.. i know wireless is not supported, so im not testing with that either of course, the messengerkit is also MS genuine)
    Code:
    C:\>cd chatpad03a
    C:\chatpad03a>chatpad_control_amd64.exe
    Chatpad control utility version 0.1a started.
    Please wait...
    Control utility started.
    Opening chatpad filter driver.
    Successfully opened chatpad filter driver.
    Successfully connected to XBox 360 controller.
    Opening connection to virtual keyboard device.
    Successfully opened connection to virtual keyboard device.
    Successfully connected to the virtual keyboard device.
    Opening connection to virtual mouse device.
    Successfully opened connection to virtual mouse device.
    Successfully connected to the virtual mouse device.
    Microsoft initialization has been finished, so we can init the chatpad now.
    IOCTL failed, lastError == 31
    Control response data received:  0x00 0x00
    Error initializing chatpad.
    Closing connection to virtual keyboard device.
    Closing connection to virtual mouse device.
    Closing chatpad filter driver.
    Done.  The exit status is -1.
    Please wait...
    Successfully sent IOCTL.  Bytes transferred:  2
    Control response data received:  0x01 0x00
    Control response data sent:  0x09 0x00
    Control response data received:  0x09 0x00
    Successfully sent IOCTL.  Bytes transferred:  3
    Reading thread started for controls data.
    Worker thread started for mouse data.
    Reading thread started for chatpad data.
    IOCTL failed, lastError == 121
    Thread shutdown detected while in ControllerReadFunction.
    Reading thread for controls data has ended, with nStatus == 0
    Thread shutdown detected while in ChatpadReadFunction.
    Reading thread for chatpad data has ended, with nStatus == 0
    Worker threads successfully stopped.
    Please wait...
    Please wait...
    Please wait...
    C:\chatpad03a>
  3. #323
    Nov 2010
    Quote Originally Posted by supporer View Post
    Hmm, thanks for the logs. I'm sorry it's not working for you. If I may ask you for a couple of favors, could you try the following:
    1. Send me a screenshot (or upload it somewhere like abload.de) of your device manager with the "Human Interface Devices", "Keyboards", "Mice and other pointing devices", and "Microsoft Common Controller for Windows Class" sections expanded. Your screenshot should look like this:
    http://www.abload.de/img/devmanagerklyb.png
    2. Are you using the latest controller driver? If not, you can get it from here just to make sure it's not an issue with the driver: http://www.microsoft.com/hardware/do...ategory=gaming If you install that, you will probably need to reinstall the chatpad drivers again afterwards, sorry about the trouble.
    3. When you got the error 121, did that error happen after like 2 minutes, or did it happen instantly?
    4. If you're up for it, could you download DebugView (http://technet.microsoft.com/en-us/s...rnals/bb896647), turn on all the options in the Capture menu besides Log Boot, and then run the control utility? Then you can use File->Save As to save a log.
    I'll be up for another 30-45 minutes but then I'll probably crash for the night.
  4. #324
    Dec 2010
    1. http://i53.tinypic.com/2u8l5pl.png
    2 > i will finish/edit this post in a moment...
    3 > i will finish/edit this post in a moment...
  5. #325
    Nov 2010
    did the computer did a reboot before the chatpad_control.exe.
    meaning install driver, reboot, then use control.exe
    bc mine wont work unless I reboot and using admin bc of win7
  6. #326
    Dec 2010
    http://i53.tinypic.com/2u8l5pl.jpg
    2. I've installed the MS drivers, then after a reboot, your chatpad-super driver
    3. Most of the times, the control program exits right away. It did wait a few times, not
    sure if that was because i pressed a button. But as you can see in the last log attempt, it
    did run a little longer (i bashed a few buttons) then the background-light goes on
    but still no further 'interaction'
    4. i made a debug log -> LOG TO FILE (with full options beside..), and fortunately, it did
    crash with a bluescreen, 0x0000010d
    its all in the log:
    http://pastebin.ca/2029564
  7. #327
    Nov 2010
    Quote Originally Posted by ddxcb View Post
    It looks like he must have used F8 to enable unsigned drivers (assuming he's on Windows 7 64-bit), but the worrying thing is that things work part of the time. Some times the controller/driver isn't responding with the data I expect it to, as far as I can tell, and that 121 error apparently means a semaphore timed out...I have no idea why that would be happening. I'm hoping that it might be due to an older controller driver but I'm not sure. I hope him upgrading the driver, or capturing a DebugView log, will help give me more information. If anyone else tries the latest install on Windows 7 let me know.
  8. #328
    Dec 2010
    I have send loads of info / trying anything i can do to help (i even crawled out of my bed of frikin christmas day for it ; D, phone beeped.. > new mail),
    but hardly anything shows up here on the forum. Im contributing -> but my posts are holded back.
    How long does it take till one can get normal posting privileges, pfffffffffffffffffffffff............
    [repost ] ,, of earlier
    its all in the log:
    And then i just did it once more, but then started capturing after i plugged it..
    Code:
    There are now 1 open handles to the chatpad filter device.
    There are now 1 open handles to the chatpad keyboard KMDF control device.
    Virtual keyboard enabled on application connect.
    Virtual keyboard enabled due to IOCTL command.
    There are now 1 open handles to the chatpad mouse KMDF control device.
    Virtual mouse enabled on application connect.
    Virtual mouse enabled due to IOCTL command.
    Microsoft initialization seems to be finished.
    Control transfer failed: 0xc0000001
    (buf 0x0 buflen 0 numbytes 0)
    Output buffer length is 32.
    Writing data synchronously to controls endpoint.
    Changed filter mode to 1.
    Control transfer failed: 0xc00000b5
    Changed filter mode to 0.
    Virtual keyboard disabled due to IOCTL command.
    The IRQL in the keyboard close handler is 0.
    There are now 0 open handles to the chatpad keyboard KMDF control device.
    Virtual keyboard disabled on application disconnect.
    Virtual mouse disabled due to IOCTL command.
    The IRQL in the mouse close handler is 0.
    There are now 0 open handles to the chatpad mouse KMDF control device.
    Virtual mouse disabled on application disconnect.
    There are now 0 open handles to the chatpad filter device.
    Filter mode set to unfiltered on application disconnect.
    [520] Chatpad control main loop finished.
    > it exits after like 10sec
  9. #329
    Nov 2010
    How long does it take till one can get normal posting privileges, pfffffffffffffffffffffff............=
    You've got 5 posts. Anything you post from now on should show up immediately. You've been a huge help, and I'm sorry the email got you out of bed! If it makes you feel any better, I've spent my Christmas day up until 3 a.m. or later twice in a row, trying to get this usable for you guys. I only wish I could do a better job of it. Go get some rest, and maybe I'll get some ideas from your logs in the morning. I sent a reply to your PM with at least one suggestion based on your screenshot.
  10. #330
    Nov 2010
    Quote Originally Posted by GAFBlizzard View Post
    thats pic looks familier on my second windows 7 x86 machine, have muti drivers for the keyboard and cant uninstall all of them.
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 09:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 10:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 04:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 05:18 PM
Tags for this Thread
