Page 41 of 71 FirstFirst ... 313233343536373839404142434445464748495051 ... LastLast
Results 401 to 410 of 709
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #401
    Dec 2010
    england
    the crash wasn't exactly when i switched to custom layout but it was while i was typing with the chatpad i m trying to get the working and because my default keyboard layout is uk which gives me the on the green r key but it switches my @ and " keys around im hoping to figure it out soon or just live with it the way it is
  2. #402
    Nov 2010
    Quote Originally Posted by masterfaz View Post
    These lines should fix @ and " and the pound symbol for the UK keyboard layout, no custom Windows keyboard layout needed:
    CHATPAD_KEY_W + CHATPAD_GREEN = KEYBOARD_KEY_APOSTROPHE + KEYBOARD_LEFT_SHIFT
    CHATPAD_KEY_J + CHATPAD_ORANGE = KEYBOARD_KEY_2 + KEYBOARD_LEFT_SHIFT
    CHATPAD_KEY_F + CHATPAD_ORANGE = KEYBOARD_KEY_3 + KEYBOARD_LEFT_SHIFT
    You'll still need a later control utility version for the # and ~ symbols, however. Of course, if you see any more bluescreens, PM or email me and we can try to get rid of them.
  3. #403
    Dec 2010
    england
    thanks blizzard will give that a try
  4. #404
    Jul 2010
    To anyone using Windows 7 x64... Other than F8 at startup, is there a way to get around the driver signature restrictions? I can't figure out how to do this part.
  5. #405
    Nov 2010
    Quote Originally Posted by kevinmd88 View Post
    You need to press F8 right after the BIOS stuff goes away, right before Windows boots. You might press it a few times to give yourself a better chance of hitting the timing window. Other alternatives are using some Windows test signing mode (if I test signed the driver), but that may display ugly watermarks, or, there MAY be a way if you're using a version of Windows 7 that's "better" than Home Premium. Try the instructions here:
    http://www.killertechtips.com/2009/0...policy-editor/
  6. #406
    Jul 2010
    Thanks for the info GAF. I do have Ultimate x64 so I'll look at that next. Right now though, it's working GREAT for me on my other computer (It has Windows 7 Ultimate x86). Kudos on a job well done!!
  7. #407
    Jul 2010
    Small bug report, not really that important but it's worth mentioning
    Unless my configuration is wrong for this... Putting this in:
    CHATPAD_KEY_LEFT + CHATPAD_KEY_SHIFT + CHATPAD_GREEN = KEYBOARD_KEY_HOME + KEYBOARD_LEFT_SHIFT
    Produces the following error, and then the control utility closes:
    Chatpad control utility version 0.1a started.
    Please wait...
    Control utility started.
    Error, expected chatpad key modifier but found "CHATPAD_KEY_SHIFT".
    There was an error parsing the following config mapping line:
    There was an error while attempting to load config file "chatpad_config.txt".
    Done. The exit status is -1.
    I intended this specific line to implement <Shift>+<Home>, which highlights text from the cursor position to the start of the current line, when Green, Shift, and Left are pressed.
  8. #408
    Nov 2010
    Chatpad keys can only be modified by chatpad modifiers, listed in the README.TXT file under "Chatpad key modifiers". You can use these modifiers after CHATPAD_KEY_LEFT:
    CHATPAD_SHIFT
    CHATPAD_GREEN
    CHATPAD_ORANGE
    CHATPAD_PEOPLE
    I did add another bug report earlier today though, since I noticed that if you hold orange and press green, instead of letting go of orange before pressing green, it doesn't seem to activate both modifiers properly. The workaround is to let go of the buttons, but I want to fix this eventually if I can.
  9. #409
    Dec 2008
    ill be trying the drivers this weekend gaf!
    i feared that once you told me i have to read a getting started page to install these drivers, it might be complicated. but after glancing at that page it actually seems like you made it as easy as it could possibly be.
    so im excited to try it. ill let you know how it goes!
  10. #410
    Jul 2010
    I think I get it now. So instead of CHATPAD_KEY_SHIFT, I would need to use CHATPAD_SHIFT?
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 10:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 05:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 06:18 PM
Tags for this Thread
