Page 47 of 71 FirstFirst ... 373839404142434445464748495051525354555657 ... LastLast
Results 461 to 470 of 705
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #461
    Nov 2010
    Quote Originally Posted by gremelin View Post
    Yes, the headset works fine with it plugged in (and non functional) and without the chatpad plugged in; as soon as I uninstalled the drivers and rebooted it worked fine...
    The port should still be on your chatpad, it's just a standard 2.5mm adapter, you can use any portable phone headset in it (in fact I was using a plantronics headset for the longest time).
    Oh yeah, that issue too. And it may be a standard 2.5mm adapter, but I'm used to 1/8" headphone jacks I guess, haha. So thus far, one person can use a headset through the chatpad with the new drivers, and one person can't. For the person who had it working, are there any special steps? Gremelin, if it shows up in device manager as a mic now, what happens if you install the drivers again without rebooting? Does that device immediately disappear? (You might have to reboot first to enable unsigned drivers though)
  2. #462
    Nov 2010
    @GAF
    Try this, it work for me.
    Quote Originally Posted by ddxcb View Post
    Hey try this.
    1) Make sure that chatpad_control.exe is closed.
    2) plug in mic into chatpad/controller
    - if the device isnt installing go to step 3
    3) with mic plug into chatpad and controller, remove the chatpad with mic and then insert back to controller.
    - if this didnt work then im not sure as i use the wireless mic.
  3. #463
    Jul 2010
    I got the abominable blue screen of death a few minutes ago when I unplugged my controller from the USB port. I figured I'd post as much info as I could, in case it was caused by the chatpad... which of course is a good possibility lol. (Just for the record, it has worked wonderfully for me aside from this )
    Some general info:
    Using Windows 7 Ultimate x86
    Chatpad "serial" is: X814365-001
    Had chatpad_control_i386.exe open when it happened
    Simply unplugged the USB connection... I didn't see anything for safe removal in the notification area.
    Not much else I can really report, other than this log I found in the Event Viewer (eventvwr.msc):
    The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
    And this under details:
    - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>2</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000002</Keywords>
    <TimeCreated SystemTime="2011-01-02T05:27:18.253213600Z" />
    <EventRecordID>26275</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Channel>System</Channel>
    <Computer>Kevin-Media</Computer>
    <Security UserID="S-1-5-18" />
    </System>
    - <EventData>
    <Data Name="BugcheckCode">127</Data>
    <Data Name="BugcheckParameter1">0x8</Data>
    <Data Name="BugcheckParameter2">0x807c8750</Data>
    <Data Name="BugcheckParameter3">0x0</Data>
    <Data Name="BugcheckParameter4">0x0</Data>
    <Data Name="SleepInProgress">false</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
    </EventData>
    </Event>
    [EDIT]
    It happened again... this time I caught a glance of the stop code: 0x0000010D
    I had the chatpad utility open again this time; on the other hand, I tried unplugging the controller without it running... no BSoD.
    [/EDIT]
    [EDIT]
    It appears to be caused by my specific setup >_< I'll try to explain this best I can.
    I had a shortcut under the Startup folder in the start menu that launched the EXE automatically. This is the command I used to do it:
    C:\Windows\System32\cmd.exe /C "C:\Chatpad\chatpad_control_i386.exe"
    My thought process for doing it this way was that by setting it to cmd.exe instead of directly to the chatpad EXE, it could be started initially minimized. *In retrospect* I realize that I could have accomplished this either way.
    Anyway, doing it "the hard way" as I did, unplugging the controller causes the BSoD. If you launch it directly, it works fine. D'oh!
    So in the very unlikely event that anyone else, now or in the future, does it this way... Don't.
    That will be all.
    [/EDIT]
  4. #464
    Nov 2010
    @kevinmd88
    ya dont unplug the controller when the chatpad_control.exe is running.
    very bad xD
  5. #465
    Nov 2010
    Thanks for the reproduce method...I was going to say I was having a hard time deciphering the blue screen otherwise. If I can get it to reproduce I should be able to track it down, thanks! Unplugging the controller shouldn't crash things, but I probably didn't try it while running the control utility.
  6. #466
    Jul 2010
    Well, what I was trying to explain in my last post is that it doesn't crash your system, as long as you open it properly.
    @GAFBlizzard
    I try to include as much info as I can when problems arise. Haha. Anyway, the following is a completely uneducated guess... but... Could the exit code have something to do with it? Maybe the actual command prompt doesn't like it...
  7. #467
    Dec 2010
    To find out how the XBOX 360 Wireless controller (connected with the chatpad) communicates with the XBOX console. So it can be implemented in the Windows/Linux drivers (GAFBlizzard and Grumbel wrote). We need to hook in a usb-analyzer between the XBOX 360 motherboard, and the RF module, that is used for communication with the controllers. As Grumbel / I pointed out earlier, the RF module is a USB device.
    I am able to spend money on a XBOX 360 for this.. but the usb-analyzer, for me, this is a problem.
    if someone reading this is able to borrow me a USB analyzer, then i'm sure we can get the wireless done
    otherwise, i will have to wait till the OpenVizsla ( http://www.openvizsla.org/ ) analyzer becomes available, and buy that.
    That may take a few months tough.
  8. #468
    Jul 2010
    Just wanted to chime in and say that Windows recognized my 360 headset when I plugged it in via the chatpad.
  9. #469
    Dec 2010
    england
    just wondering if anybody could help me. I still cant figure out how to get backslash with chatpad using uk keyboard layout.
  10. #470
    Nov 2010
    Quote Originally Posted by masterfaz View Post
    There's a fix for that, but I need to get the latest source files off my laptop, and include it in the next overall driver release. If you need it sooner, I can do a test build of just the control utility for you.
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 09:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 10:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 04:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 05:18 PM
Tags for this Thread
