First off, your comp is blue screening when the wire shorts out because I have a bug in one of my drivers that I still need to fix...the same thing would happen if you unplug the controller while the control utility is running. It should be fixed in the next release.
Secondly, there should be a mouse sensitivity value that can range from 1 to 20 in the chatpad_config.txt file, near the top. Hopefully this will work well enough for you, for now, because I don't have any mouse acceleration built in, which may be what you mean by "spring". Also bear in mind that if you move both thumbsticks instead of just one, the mouse will move faster, so that may help you out as well.
