Page 52 of 71 FirstFirst ... 2424344454647484950515253545556575859606162 ... LastLast
Results 511 to 520 of 709
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #511
    Jan 2011
    Hey, just signed up to say great job, and that I wish it worked for me.
    I'm using an original wired Xbox 360 controller with the new chatpad, on win7ultimate x86 and my control utility output looks like this:
    Chatpad control utility version 0.1a started.
    Please wait...
    Control utility started.
    Opening chatpad filter driver.
    Successfully opened chatpad filter driver.
    Successfully connected to XBox 360 controller.
    Opening connection to virtual keyboard device.
    Successfully opened connection to virtual keyboard device.
    Successfully connected to the virtual keyboard device.
    Opening connection to virtual mouse device.
    Successfully opened connection to virtual mouse device.
    Successfully connected to the virtual mouse device.
    Microsoft initialization has been finished, so we can init the chatpad now.
    IOCTL failed, lastError == 31
    Control response data received: 0x00 0x00
    Error initializing chatpad.
    Closing connection to virtual keyboard device.
    Closing connection to virtual mouse device.
    Closing chatpad filter driver.
    Done. The exit status is -1.
    Any suggestions, fixes, and support would be greatly appreciated.
  2. #512
    Nov 2010
    Quote Originally Posted by crouchingrat View Post
    Hopefully you just need different initialization codes, but I dunno. First, unplug and replug your controller. Then, for 32-bit Windows 7, try downloading this and running it from the same directory as your chatpad_config.txt file:
    https://code.google.com/p/chatpad-su...4.exe&can=2&q=
  3. #513
    Jan 2011
    That seems to have gotten the mouse portion to work, but no dice on keyboard functions.
    Current dialog on the control application is as follows:
    Please wait...
    Successfully sent IOCTL. Bytes transferred: 2
    Control response data received: 0x09 0x00
    Control response data sent: 0x01 0x02
    Control response data received: 0x01 0x02
    Successfully sent IOCTL. Bytes transferred: 3
    Reading thread started for controls data.
    Reading thread started for chatpad data.
    Worker thread started for mouse data.
    Any help is still appreciated, and so far so good.
    EDIT:
    I think it may be a small problem with the keybindings on my computer, as when I use an unbound key combination, it puts something along the lines of "No action binding found for 0x19 + 0x6." in the command prompt, but when I press anything else, it does nothing. Again, the mouse is working beautifully, but the keyboard not functioning is most likely a problem with the keybindings on my end, even though I haven't touched the keybindings file. Just a heads up.
    EDIT THE SECOND:
    Just a question, am I supposed to have 5 keyboards listed for the chatpad in device manager? I clear them out after an uninstall, because after one bad installation, I got a bluescreen, uninstalled, cleaned out device manager, and it installed 5 keyboard drivers, and i don't have the option to remove at least 2 of them.
  4. #514
    dsp
    dsp is offline
    Jan 2011
    binding alt-ctrl-delete
    First off the driver works great on my 64 bit windows 7 comp and the on-the-fly mouse emulation was a great idea so kudos to gafblizzard for all his hard work. I could use a little help with the config file though. I'm trying to assign the spacebar key with the green modifier to bring up the task manager, but i can't get the control program to start after assigning any button to perform either SPECIAL_ACTION_LEFT_CTRL + SPECIAL_ACTION_LEFT_ALT + KEYBOARD_KEY_DELETE or KEYBOARD_LEFT_ALT + KEYBOARD_LEFT_CONTROL + KEYBOARD_KEY_DELETE. Is there any way I can get this to work?
  5. #515
    Nov 2010
    Quote Originally Posted by funni64 View Post
    Very exciting. Any word on mouse configuration with the thumb sticks?
    I'm not quite sure what you're asking...the current drivers support using the thumbsticks to control the mouse.
    That's almost certainly the problem, because I STILL have not finished my uninstall stuff. You should have a Device Manager that matches something like this:
    http://h-3.abload.de/img/devicesqhvq.png
    If you don't, follow the instructions in the Troubleshooting section of the Getting Started guide (http://code.google.com/p/chatpad-sup...GettingStarted) to uninstall the extra devices. You can try only removing the duplicates, or removing them all and reinstalling. You probably need to uninstall the keyboard/mouse device before you can remove the corresponding Human Interface Device, otherwise you won't have the option, at least for the keyboard, if I recall correctly.
  6. #516
    Aug 2010
    hey guys, dont know if this is of any use. i baught an unofficial chatpad recently. when i connect it to my wireless controller windows picked up new hardware. after install i checked out device manager and it was listed as usb audio divice. i then unplugged the unofficial chatpad and plugged in an official chatpad and nothing happened. anyway it say on device properties XBOX_360_DEVICE_00:03
  7. #517
    Jan 2011
    Thanks and a suggestion(sorry)
    I just want to thak you for doing this. I have a wireless controller, so I am unsupported at the moment, but at least the framework is there.
    I have a single wireless receiver and the white controller that came with it and then the new one that comes with the slim. Will buy a chatpad in the next month and am willing to help test if possible/needed.
    I know you have worked hard, but would it be possible to make the d-pad be usable as arrow keys? Or would joy2key be a better choice for that.
    On that note, is is possible for joy2key to use the enable mouse button for on and off and finally, would it be possible to use only one stick for a mouse as when I use joy2key currently I set the right-stick to scroll.
    Thank you once again for this, hopefully by the end of this year there will be wireless added somehow.
  8. #518
    Nov 2010
    Quote Originally Posted by Mike43110 View Post
    I have made note of your suggestions, and most of them should be possible, so we'll see. What do you mean by this, though? You want a button on the chatpad itself to communicate with joy2key?
  9. #519
    Nov 2010
    Quote Originally Posted by GAFBlizzard View Post
    I use joytokey for the mouse/game/anything etc.
    just replace the people key from mouse to what ever you want.
    I found something out on the wireless reciever,
    if the wireless controller sync to xbox then plug a charge in play into pc with reciever,
    it connects to the reciever like an xbox would.
    thus it send data to the reciever threw the charge cord.
  10. #520
    Jan 2011
    Sweet merciful crap, gaf, it's working! If I knew where you were, I'd hug you. Thanks for the driver, all your hard work, and if you need any more testing, don't hesitate to ask, I'd be more than happy to help in whatever way I can.
    This was typed using my Xbox 360 chatpad, and my typing speed only dropped from 80wpm to about 20-30.
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 10:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 05:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 06:18 PM
Tags for this Thread
