Page 60 of 71 FirstFirst ... 10505152535455565758596061626364656667686970 ... LastLast
Results 591 to 600 of 705
Thread: CONTEST: Xbox Chatpad Driver Challenge
  1. #591
    Mar 2011
    Quote Originally Posted by GAFBlizzard View Post
    Quick update for tonight. As part of my to-do list, I tested unplugging and replugging the controller tonight. No matter whether I have the control utility running or not, I did not get any bluescreen crashes on Windows 7 64-bit home premium. It could be that I fixed the bug and just haven't released the code to everyone yet. :/ It should be in the next release if so.
    If anyone DOES have the unplugging crash on Windows 7 64-bit home premium, let me know, since that hopefully means it's fixed. XD
    I have the unplugging crash on Windows 7 64-bit and I sent you a pm as well. Looking forward to you response and a hopeful fix. Thank you for all that you are doing GAFBlizzard.
  2. #592
    Feb 2011
    I'm running Windows 7 64-bit home premium also, and I get the blue screen crash almost every time I unplug. It doesn't seem to matter if I am in mouse or joystick mode, and it also doesn't seem to matter if I close the utility and wait awhile, sometimes I quit the utility wait a few minutes and unplug okay, more often though I get the blue screen stop error. Any idea on a timeframe for the next release? My workaround right now is to shutdown my PC when I'm done playing a game but that's kind of a pain since you have to constantly do the driver signing enforcement on boot up, and I'd like to just disable it and let my PC on all the time. Please let me know if you need any troubleshooting info from my machine if it could be helpful at all, and I'll get you a quicker response next time
  3. #593
    Mar 2011
    Hey, First post...
    Just want to start off by saying all the work you've put into this is stupendous! Really looking forward to getting the chatpad working on my system.
    Onto my question, I couldn't find anywhere else that had this problem, so i thought I would post here.
    (Edit: Found an issues placeHere where I posted in reply to this same issue.)
    Installed and everything seemed to go okay.
    When I ran chatpad_control_i386, the command prompt instantly crashes at Please Wait...
    Opened an administrator Command Prompt and re-ran the file, and got the following.
    Chatpad Control Utility Version 0.1a started.
    Please wait...
    Control utility started.
    Opening chatpad filter driver.
    Couldn't open chatpad filter: 2
    Failed to open connection to XBox 360 controller.
    Done. The exit status is -1
    I am running a windows XP system, and the controller is currently plugged in with the current drivers from MS.
    Thanks for everything, and I hope perhaps my little extra bit of information helps out in the debugging of this problem.
    ~Fox
    P.S. Sorry for the long message......
  4. #594
    Nov 2010
    Blackfox, do you have an official Microsoft wired 360 or "made for Windows" controller? The error code 2 indicates that the device could not be found, I think. That should only happen if the installer was not able to detect the controller and attach a filter driver. If you have a "special edition" controller or a Mad Katz version that could be the problem, for instance. I know Mad Katz does not work with my driver so far (may need yet another set of initialization codes or something like that).
  5. #595
    Jun 2010
    Vancouver, Washington, United States
    Thumbs up
    GAFBlizzard,
    I just wanted to say this, though I'm sure within the 600 replies this thread has, you've been told many times:
    Thank you for stepping up on this and getting done what Microsoft refuses to put any effort into.
    That being said. Because of this driver you've written, I will use the chatpad and my wired 360 controller, instead of an expensive (by comparison) bluetooth mini keyboard.
  6. #596
    Mar 2011
    No, I have an official wired controller. I actually believe this was the controller that came with my first Xbox 360 that I bought several years ago...I know the controller is connected, and windows is finding it fine, as I have the lit up ring, and Xpadder can find it just fine. Not sure why the driver wouldn't be able to find it....
    I'll see what I can come up with, until then, any thoughts??
    Thanks again,
    ~Fox
  7. #597
    Nov 2010
    Quote Originally Posted by Blackfox42 View Post
    Thanks again,
    ~Fox
    Hmm. Can you post a screenshot of your device manager, with any sections that are related to the 360 controller and/or chatpad expanded?
  8. #598
    Mar 2011
    ok so it seems that while xpadder could find my controller, the drivers couldnt. after some fiddling around (and a couple of reboots) i was able to get it working. Im not entirely sure what happened, but i think it had to do with needing a reboot and some extra devices that were floating around from previous attempts. Regardless, its working great now, as evidenced by the fact that this was typed via my chatpad.
    Thanks Gaf!!
    ~Fox
  9. #599
    Apr 2011
    GAFBlizzard,
    FYI, I was able to install the chatpad_0_0_3a_winxp.zip package on Windows Home Server, which is based on Windows Server 2003 32-bit. The Xbox 360 controller appears as a generic HID game controller. This is great news because the Microsoft driver does not support Windows 2003 and refuses to install, and I had no luck using the XBCD driver which installed but could not start the controller (code 10).
    Rumble and headset audio output are working in the games that support it and let me choose the controller as audio output. I haven't tested the mic. The OS rebooted once when I unplugged the controller but it looks like one of the known issues being worked on.
    Thanks GAFBlizzard!
  10. #600
    Nov 2010
    Do you mean you're using it without the chatpad? Or the chatpad AND the rest of it work now that you installed that package?
    I'm...rather surprised it worked actually, haha. My sympathies for you being stuck with Windows Home Server. :P
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 09:32 AM
  2. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 10:52 AM
  3. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 04:31 PM
  4. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 05:18 PM
Tags for this Thread
