Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: LCD lifter parts?
  1. #11
    Jun 2008
    Perth, Western Australia
    What about a linear actuator?
    Build it inside a new back cowling, so you cant see the actuator when you look through the front windscreen at the back of the LCD screen, and you could have the linear actuator raise and lower the screen.
    They are powerful, smooth, quiet, and VERY reliable. You can have them work much like a car antenna, they have 12V power all the time, with a trigger line from the car computer. When the computer is off, the actuator retracts back into the dash, when the computer is on, the actuator extends, and raises the screen from the dash.
    That would be the easiest option, and it keeps the number of moving parts down, as you only have sliding channels on each side of the screen, with the actuator being the only moving part.
  2. #12
    Low Bitrate Rillee's Avatar
    Jan 2007
    Sweden
    Yes thats sounds like a good way to go.
    How compact are they? Because i dont have any space under the lcd
    And can i get them in the right size?
  3. #13
    Jun 2008
    You can get ones with as small as a 4inch throw, so the total body length is only about 5 inches total. You would mount it behind the screen, and have it attach to the screen up at the top, making the whole unit sit behind the screen when it is down in the dash.
    Just do a google search on Linear Actuators, and you will find there are a heap of sizes and stuff on offer, admittedly they aren't super cheap, but they are a part that almost never fails, and you can choose from either high speed, low force, or low speed, high force.
  4. #14
    Jan 2007
    Sweden
    If i put at the top of the lcd, the Linear Actuators will also be visible.
    I want to put it at the bottom of the lcd like my lego design so only the
    lcd will be visible.
  5. #15
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    When I google I mostly find pneumatic ones, and the electric ones are huge! Is it not true that electric ones are built with a screw and a DC motor?
    Would be great if you could point to a feasable one for this project, Chester.
    My intuition is that for size requirements, best way is to build it up myself from a screw. Most mechics will be guides to let the LCD move nicely anyway, so not a lot of work to be spared there.
    CD approch was interesting though. Compact, very often strong, and stroke is about right too. Maybe even guides could be reused. Almost like attaching the LCD panel on the back of it. Problem might be to find one that is not too fast...
  6. #16
    Jan 2008
    maybe a small, compact motor like this can help?
    http://www.goldmine-elec-products.co...?number=g16279
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  7. #17
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Well heck. In that case... Not sure about the travel:
    http://www.allelectronics.com/make-a...ENCODER/1.html
    24V but might be a good speed at 12V. Stick a couple rods on the bottom and have this against 1 rod. Snap action switches at the ends to stop it.
    http://www.allelectronics.com/make-a...RNTABLE/1.html
  8. #18
    May 2007
    Quote Originally Posted by Rillee View Post
    Ok, so mount the actuator upside down so it attaches at the bottom of the screen (in this case the actuator would be fully extended). And when it retracts, your screen will raise up.
  9. #19
    Sep 2005
    Stockholm, Sweden
    Quote Originally Posted by Curiosity View Post
    Nice products on that site! Thanks, have not seen it before.
