Page 14 of 17 FirstFirst ... 4567891011121314151617 LastLast
Results 131 to 140 of 164
Like Tree1Likes
Thread: Interested in a USB Audio Amplifier?
  1. #131
    Dec 2008
    Quote Originally Posted by steven765 View Post
    LAUGH. MY. FREAKIN. A. OFF!!! hahahahaha, that is the funniest thing ive seen in a long time... genuinely busting up here... hahahahaha!
  2. #132
    Mar 2006
    Colorado, but Canadian!
    I have some updates. I have had a crazy year working on other higher priority projects. I might have some more time to renew interest in this as I have the framework built and a new system to get prototypes up and running.
    Stay tuned. Still nobody has anything like it on the market which is both astonishing and sad.
    1.9in x 2.9in -- 47mm x 73mm
  3. #133
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    I'm interested in this. Keep us posted.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  4. #134
    May 2012
    Grandville, MI
    Yup, you should make this a relatively high priority I would say...
    If possible it should also be as generic as possible so it will work right out of the box with Windows or Linux machines. Would be great if it was recognized by the newer androids devices as an external sound device but I don't know if the androids can support that. I should plug one of my USB sound cards into my Galaxy SIII and see if they are recognized... Hmmm...
  5. #135
    Mar 2006
    Quote Originally Posted by redheadedrod View Post
    I am following the USB Audio standard. This means it will work out of the box with Linux and Windows. It is hit or miss with OSX because they decided they are above the standard and I am not making it work with OSX just to make it incompatible with Windows and Linux.
    I have an SIII, and I haven't tried USB Audio. I don't even know if it is supported. But yes, my intentions were to after releasing something that works with a wire, make a version that supports bluetooth audio. The sound quality will be lower obviously because bluetooth can't handle the bitrate, but that should make tablet/phone installs much easier.
  6. #136
    May 2012
    Grandville, MI
    Quote Originally Posted by 2k1Toaster View Post
    If you have the adapter the SIII just recognizes things.. I already verified you can plug in flash cards, hard drives, mouses and keyboards. There is not much power however so it will tell you if the device is asking for too much power and not allow it to connect.
    I have a generic tablet here as well that even came with the adapter included but I haven't done much with it.
    Rodney
  7. #137
    Mar 2006
    Status Update April 08th, 2013:
    I have working hardware that will output low-level 8 channel, 24bit, 96KHz sound. So that is 7.1 audio using Windows sound outputs at better sound quality than most sound cards. Now I can (hopefully) bolt on my amplifier and voila!
  8. #138
    Nov 2010
    Hong Kong
    Quote Originally Posted by chris350 View Post
    It turns out that the particular model (http://tabletrepublic.com/forum/late...view-3203.html) that I am interested in is not available in Hong Kong. So I will need to find a reliable mail order source in China to get it. I will keep you posted.
    On Audio over USB I have a Sony Xperia Z (4.1.2) which supports my Fiio USB D/A without issue, but my other phone, Samsung Note (stock 4.1.2) will not. So it all depends on the kernel. I hope the x7 would have this function (fingers crossed)
  9. #139
    May 2012
    Grandville, MI
    Do you know if it will work with Linux at all?
  10. #140
    Mar 2006
    Yes. It will work with OSX and Linux. I actually had to make the tough decision to back away from USB Audio 1.0 and 1.1 and move into 2.0. It is the newer standard, not many people are doing it, but it gives better control over the lines, a faster bit transfer rate and speed for more resolution, higher frequency output, and lots of other things. So Linux and OSX support it natively, Windows needs a driver because Microsoft has decided nobody needs that sort of sound from a PC and just doesn't bundle it with the OS. Android and iOS also support it.
    But to get the sound and channels I wanted, it had to be done.
    The better news, is that since my last amplifier design, the silicon company released a new product that seems to have addressed the issue I was having. So I am going to re-layout that board and see what's what.
  1. Small and simple USB audio amp anyone?
    By JC-S60 in forum User Innovations
    Last Post: 04-10-2011, 10:09 AM
  2. USB Audio codec just isn't there...so no sound
    By ramrod in forum BoomzBox HD
    Last Post: 07-14-2010, 09:13 AM
  3. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  4. No audio from line input for sirius usb adapter
    By Ryan711 in forum Car Audio
    Last Post: 09-08-2007, 08:07 PM
  5. PCI Audio vs. USB Audio vs. Onboard Audio
    By waltwalt in forum Car Audio
    Last Post: 07-26-2007, 09:36 AM
