Page 16 of 17 FirstFirst ... 67891011121314151617 LastLast
Results 151 to 160 of 164
Like Tree1Likes
Thread: Interested in a USB Audio Amplifier?
  1. #151
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by eeguru View Post
    What about a simple lower power but still fully digital amp that doesn't require a boost power supply? I'm thinking Silicon Labs CP2114EK USB to I2S bridge, STMicro TDA7802 I2S AMP - 28W x 4 channel @ 4 ohm from a 14.4 V supply, large inductor & cap to filter alternator whine, and perhaps a small PLD to fan stereo to 4-ch w/ fade control.
    I'm not sure I'd have the time to build up and sell kits, but it would be a purely open hardware design so anyone could build and modify it. It's basically the same type of high efficiency class AB amp in most head units.
    There are plans for a smaller, lower cost version. But I don't do small then work up. I do the best thing I could possibly think of, that nobody else has even come close to doing, then if there is time make a smaller less feature packed version for those that don't want the uber version.
    My tiny amp would be a Class D like this one.
    1.9in x 2.9in -- 47mm x 73mm
  2. #152
    Mar 2006
    Quote Originally Posted by chris350 View Post
    Class AB amps suck balls. Very inefficient. Class D profile would be the way I'd go. But then again I'm not designing it.
    It will be Class D if I design it.
    AB has its place, but in today's systems there is no advantage anymore. The silicon and designs used in the FETs of today are so far superior to what they once were that the turn on times are essentially instant and the power drive phenomenal. The only legit reason for a Class A, Class B, or Class AB amp today is nostalgia. But that is a valid reason. Same reason I keep my old game consoles alive and working even though I have all the ROMs and emulators.
  3. #153
    Nov 2002
    Atlanta, GA, USA
    I'm not sure the efficiency argument works in the 'CarPC' universe. As long as you get the heat out and the amp performs reasonably well, it's fine - we're only talking about 100W total. The TDA7802 is a new product and SB-I class which is the highest AB before D. The delta isn't much. And it's difficult to find all-in-one class D's for head unit use (no boost supply & stop/start) that have I2S inputs and are not costly. A small amp could be built that is literally a BFI, BFC, amp, I2S/USB bridge chip, a small PLD, a few decoupling caps and literally not much else beside a milled aluminum box to put it all in. I'm always traveling for work, but I will try to eek out a design over the next couple weeks (out of country all next week).
    I am intrigued by your larger amp design. I'm assuming you work for an amp company. Tuning the output filters is where the most work will be. It's easy to put together a PWM driver, H Bridge, and LC filter and have it be very efficient. It's hard to make it sound great! Will you be sharing any part of the design?
    Good luck.
    Save virtual trees....
  4. #154
    May 2012
    Grandville, MI
    eeguru, if you have a design you would like to build maybe you should start your own thread instead of hijacking Toasters thread...
    No problem having more than one design but you shouldn't be advertising your own potential attempt in another developers thread.
    Just saying...
  5. #155
    Nov 2002
    Atlanta, GA, USA
    Quote Originally Posted by redheadedrod View Post
    Just saying...
    I wasn't suggesting my own design. I was suggesting maybe doing a project with a smaller scope would help get to the finish line - along with my help. You are right though, I should have posted my own thread with the exact same name. For some reason I thought a 3 year long thread was enough time before suggesting an alternative here.
    firefighter484 likes this.
  6. #156
    May 2005
    any updates?
  7. #157
    Mar 2006
    Quote Originally Posted by chiefwigms View Post
    any updates?
    My appendix exploded last month and I was in the hospital for a couple weeks and out of work for almost a month. I am still catching up on work-work, so this is on the backburner. Life just keeps happening
  8. #158
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    WOW glad your on the road to recovery. SNO
  9. #159
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I'm sorry to hear that, take care of your self, this stuff can all wait. Without good health & an income, life is a lot less fun...
  10. #160
    Dec 2010
    Twilight Zone
    I know its been a while, still any more updates?
    As of 4-10-14
    CarPC Progress: 60%+ Starting from scratch with old laptop. Trying to figure out how to get all the programs I want/need for RideRunner!
    My Build/Install Thread
  1. Small and simple USB audio amp anyone?
    By JC-S60 in forum User Innovations
    Last Post: 04-10-2011, 10:09 AM
  2. USB Audio codec just isn't there...so no sound
    By ramrod in forum BoomzBox HD
    Last Post: 07-14-2010, 09:13 AM
  3. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  4. No audio from line input for sirius usb adapter
    By Ryan711 in forum Car Audio
    Last Post: 09-08-2007, 08:07 PM
  5. PCI Audio vs. USB Audio vs. Onboard Audio
    By waltwalt in forum Car Audio
    Last Post: 07-26-2007, 09:36 AM
