Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 164
Like Tree1Likes
Thread: Interested in a USB Audio Amplifier?
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by justchat_1 View Post
    That costs ~$200+shipping, has had numerous quality issues and is only 16bit 2 channel sound. This is a 5 channel HD amp, and based on 2k1toasters other products we all know will be great quality at an affordable price.
    Thanyou very much, I am glad you guys like it. Its not like any of this pays the bills, it is just fun and helps out a still growing community. I can do electronics, so I give back that way.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Jan 2007
    Canada
    When/if I ever decide to take the carputer plunge this is an item I would definitely be interested in.
  3. #23
    Jun 2010
    Love it and I would buy one. How difficult would it be to do a 5.1 setup or make it selectable between 4.1 and 5.1? Just a thought as I have 5.1 in my car.
    The best forum start place is here but damned if I could find it. I had spent several weeks on the forum before finding it.
  4. #24
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    pass-thru line out please, so additional amps can be added. Oh, and perhaps an option to connect a physical knob for a hard volume control.
    So if I'm correct, this sounds like a DAC with an amp built in, not really a sound card.
    Will still have to use a sound card or audio switcher to use radio modules, to this date I haven't had a lot of luck with that.
    Price sounds good.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  5. #25
    Mar 2006
    It is a soundcard. Plug it in, and the OS recognizes a sound card and pumps audio to it. I have no plans for audio input to the PC though. Might be able to have a non-PC passthrough though.
    Just remember every feature is more cost...
  6. #26
    Vendor - Qube colin's Avatar
    Dec 2006
    What chip did you plan on using for audio processing? Or is that confidential?
  7. #27
    Jan 2008
    overall, i think that keeping it at/around 150-250 is a reasonable cost for a quality usb controlled amp-- according to crutchfield-- most 4 channel amps are also in that rough price range of at least $100+ 4.1 amps seem to go for at least $350... keep in mind these are all name brand amps--basically what this amp would/should compete with... while there are definitely cheaper off-brand amps, this would not seem to be the target...
    i can think of 1 change though, unless you know of a amp chipset that can provide the power for the sub(i would say at least 100 watts rms-- i am not familiar with amp chipsets, so it might be cheaper to just include it...), maybe just provide a preout for the sub channel? imo, even just a 4ch amp would be great for most-- as long as they have the option to add a sub.
    while the amp does not interest me (i prefer to build my own setups-- with sound card, and higher power amps) i think that it could provide a huge help to the new people getting into this whole carpc thing by providing a easy plug-n-play solution to the entire amp issue-- lets face it, the idea of hacking together radioshack adapter cables, and discount motorcycle amps to get audio in a car doesn't sit well with most...
    most of the people on this forum are not interested in perfect audio quality or adding aftermarket amps-- most just want clear audio to come out of their factory speakers from the computer that they wanted to install, so a amp like this would provide a great solution that they don't have to mess with to much, and will be designed to work with a carpc..
  8. #28
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by 2k1Toaster View Post
    There is a fully designed system. I work fast. I do not have it laid out or anything but all preliminary components are selected.
    wow you do work fast!! By final design I meant designed, tested and ready to be manufactured but the fact that you did so much so quickly is very good sign.
    The only question I didn't see asked here....is how small of a footprint will this end up being? I know exact dimensions are probably not available at this point but is it something that will easily fit in a 1-din space of a dash?
  9. #29
    Mar 2006
    I wasnt planning on making it DIN sized. I was figuring on making it look like an amp. But like I said, I have not laid it out yet.
    What type of footprint do you guys want? The limiting factor here is not component size (they are small), but heat dissipation. At high powers, this thing will get... toasty.
  10. #30
    Mar 2004
    Greenacres, WA
    That's a DAC, not a soundcard, but I guess I'm just splitting hairs. This may end up being a no go for those that want to run a Directed HDRadio, or XM or Sirius, as I cannot get my Directed or my XM to work with my setup. I'll be digging into my issue more tomorrow and will provide more feedback.
    I realize additional features cost additional $$$. You need to balance between the two to have a successful product. I see someone else has also asked about line in pass thru, probably should also be able to bridge outputs, for those that want more power.
    Just offering suggestions, I thought that was what was wanted.
  1. Small and simple USB audio amp anyone?
    By JC-S60 in forum User Innovations
    Last Post: 04-10-2011, 10:09 AM
  2. USB Audio codec just isn't there...so no sound
    By ramrod in forum BoomzBox HD
    Last Post: 07-14-2010, 09:13 AM
  3. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  4. No audio from line input for sirius usb adapter
    By Ryan711 in forum Car Audio
    Last Post: 09-08-2007, 08:07 PM
  5. PCI Audio vs. USB Audio vs. Onboard Audio
    By waltwalt in forum Car Audio
    Last Post: 07-26-2007, 09:36 AM
