Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: DIY self-powered USB hub... is it possible?
  1. #11
    Jul 2006
    Northern CA
    ... can't you just cut the coaxial plug and wire in your own "DC-connection" and fuse it? And as for the ignition switch, if it's hooked up to the right line, shouldn't it automatically turn off when the key is out?
  2. #12
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by Chronus72488 View Post
    Sure, you could run power out of your computer's PSU to the hub, (Not ignition, since that's unregulated voltage and a good way to kill it). Let us know how that works for you? It won't turn the devices off before your PC shuts off, which could cause issues if you run hibernation but I don't see any other problems with that setup besides having to hack it together.
    RevFE
    My Shop
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If that's $85...
    http://www.amazon.com/D-Link-DUB-H7-...2520046&sr=1-1
    Shouldn't that be like... $150?
    Besides it being DC-powered and turning on with the ignition... I don't see the difference...
    Why are DC-DC ATX PSU's much more expensive than standard ATX supplies?
    Because they are specially designed to work in the car. And work is the operative word here.
    Like I said, don't argue the price.
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yes, you can do that. I presume you mean you will be running the proper voltage into the DC connection. Most USB stuff is 5 volts, so don't run 12v into it unless that's what it says on the power supply.
    The additional features of the mp3car hub include a timer that keeps the hub on for a certain amount of time to allow you to stop at, say, a gas station without the USB devices going offline. The hub also solves many of the problems people have with USB devices that go missing when the system hibernates or sleeps.
    And yes, you can wire up a timer relay to a powered hub and it will work. You can hack it all together if you want. The mp3car hub just does it in a nice package that works properly.
    Want to:
  5. #15
    Jan 2008
    Dartmouth, MA
    The voltage is the number one issue here.
    Pumping 12 volts from the car into a USB device will fry it.
    You need to give a hub 5 volts.
    I agree that the $85 hub price is a bit ridiculous, but it saves a lot of the trouble found with other solutions and is much more rugged/reliable.
    If you do want to go the cheaper route, get a hub with an external power supply. Cut the wire and feed 5 volts over the wire with the proper polarity. If ever confused about whats positive or negative, check it with a multimeter.
    Ways to get 5 volts:
    -12 volt to 5 volt "point of load" power supply.
    ---Converts 12 volts from the car into 5 volts for the usb hub
    ---This costs about $30.
    -Using the 5 volt power supply that the computer already has.
    --This costs whatever the length of wire from the computer to the USB hub will cost you
    --Look at a hard drive connector from the computer's power supply. The red wire is positive 5 volts, the black wire closest to it is the negative wire for the 5 volt rail.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #16
    Jun 2009
    London, United Kingdom
    I've got a cheap 5 port belkin hub which had a 5v socket but no adapter, cost about 4 ($7 or so) got the 5v from my M2-ATX- had zero issues.
  7. #17
    Oct 2010
    Are you all still under the impression that you actually need a hub with a plug on it?
    You all know USB is 4 wires. 2 of them are data which you don't touch. The other 2 are the 5v. Generally the red wire and then ground.
    So why would you need to buy a 7 port hub with a plug and all? just buy a normal hub that has some wires, or buy some extension cables and splice the wires.
  8. #18
    Jun 2009
    lol, that sounds like a lot more hassle than its worth! Considering a powered hub costs next to nothing and just requires a simple 5v feed...
  9. #19
    Oct 2010
    yeah, well if you didnt want to wait around for a powered hub, and you already had another one I was saying.
    Its not like the powered ones have any electronic components for the power, thats all. Its the same 5v.
    Also, I think I saw someone say its 100ma? It should be known that this is true by specification but pretty much nothing follows the spec. Most systems have at least 500ma and many devices draw more.
  10. #20
    Raw Wave
    Nov 2009
    500mA to 1A (1,000mA) USB loads are not uncommon - eg, GPS, external disks.
    I've been meaning to check the "USB Spec" to see if it specifies "minimum" or maximum power per output (or load LOL) to be 500mA etc. Maybe next year....
  1. usb car charger powered hub?
    By boxlifeusa in forum General MP3Car Discussion
    Last Post: 07-26-2010, 01:22 PM
  2. Powered USB Hub Anyone?
    By Lukeyson in forum General Hardware Discussion
    Last Post: 07-09-2009, 05:54 PM
  3. 5v Powered usb hub help
    By dhantiflag in forum General Hardware Discussion
    Last Post: 06-11-2009, 10:41 AM
  4. Self Powered USB hub that actually works with more than one item!
    By mcoutlawz in forum General Hardware Discussion
    Last Post: 02-26-2009, 09:29 AM
  5. installing a powered USB Hub.....questions?
    By mygti02 in forum Power Supplies
    Last Post: 11-01-2007, 02:05 PM
