Results 21 to 30 of 31
Thread: DIY self-powered USB hub... is it possible?
  1. #21
    Jan 2008
    Dartmouth, MA
    Read the wikipedia USB page's power section at: http://en.wikipedia.org/wiki/Universal_Serial_Bus#Power
    In a nutshell:
    A USB port in standard mode is allowed to output 500mA.
    A USB port in charging mode is allowed to output 1.5 A.
    A completely dedicated USB charging device is allowed to output 1.8 A.
    Standard USB connectors are rates at 1.5 A.
    Relevant portions:
    Quote Originally Posted by wikipedia
    The USB 1.x and 2.0 specifications provide a 5 V supply on a single wire from which connected USB devices may draw power. The specification provides for no more than 5.25 V and no less than 4.75 V (5 Vą5%) between the positive and negative bus power lines. For USB 2.0 the voltage supplied by low-powered hub ports is 4.4 V to 5.25 V.
    A unit load is defined as 100 mA in USB 2.0, and was raised to 150 mA in USB 3.0. A maximum of 5 unit loads (500 mA) can be drawn from a port in USB 2.0, which was raised to 6 (900 mA) in USB 3.0. There are two types of devices: low-power and high-power. Low-power devices draw at most 1 unit load, with minimum operating voltage of 4.4 V in USB 2.0, and 4 V in USB 3.0. High-power devices draw the maximum number of unit loads supported by the standard. All devices default as low-power but the device's software may request high-power as long as the power is available on the providing bus.
    In Battery Charging Specification, new powering modes are added to the USB specification. A host or hub Charging Downstream Port can supply a maximum of 1.5 A when communicating at low-bandwidth or full-bandwidth, a maximum of 900 mA when communicating at high-bandwidth, and as much current as the connector will safely handle when no communication is taking place; USB 2.0 standard-A connectors are rated at 1500 mA by default. A Dedicated Charging Port can supply a maximum of 1.8 A of current at 5.25 V. A portable device can draw up to 1.8 A from a Dedicated Charging Port. The Dedicated Charging Port shorts the D+ and D- pins with a resistance of at most 200Ω. The short disables data transfer, but allows devices to detect the Dedicated Charging Port and allows very simple, high current chargers to be manufactured. The increased current (faster, 9 W charging) will occur once both the host/hub and devices support the new charging specification.
    So it depends on the device.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  2. #22
    Dec 2008
    check out jameco for industrial power supplies. we install these on multi million dollar jobs all the time, they are really nice for the cost. i use a 5a, and i just gave a generic $10 7 port hub wired to it. there are some really bad el cheapo usb hubs out there, but theres a lot of decent ones too that wont cause any problems, especially when speed isnt much of an issue (usually not when you are using a hub)
  3. #23
    Jan 2008
    Dartmouth, MA
    I can also vouch for those Jameco power supplies. I'm using them in my install and they work BEAUTIFULLY.
  4. #24
    Raw Wave
    Nov 2009
    Thanks PaulF for the early new year.
    No thanks for causing me to review the link ahead of the new century, but my curiosity for suspected ambiguities won out.
    In my earlier reply (lost due to the mp3car "malware" warning) I thought many would probably be confused by "USB ... is allowed to output 1.8 A" (but) "Standard USB connectors are rated at 1.5A". Alas, not me! But I'm used to Specs - others often see them as fabricated and contradictory.
    [ Rem: Did I tell of my mate's woe - arguing that Anderson DC connectors were NOT for interrupting current? Alas an Aussie lunchtime-legend argued that he only bought "quality USA-made Andersons"...
    LOL - they have the same "no-interruptus" embossing as the others, though they only have it in French and omit the English. Because they provide a Spec for "interruption operations at rated current" does not mean they are suited or intended for interrupting current!
    But it was one more stat point for the hypothesis that morons don't read French.
    And not many Australians read French. ]
  5. #25
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by OldSpark View Post
    Is there an English version of this post available?
  6. #26
    Raw Wave
    Nov 2009
    Certainly.
    I'm sure Paul will ask if he wants clarification.
  7. #27
    Jan 2008
    Quote Originally Posted by Enforcer View Post
    blah,blah, read a new review, blah, blah.
    replied earlier, but it got lost. usb ports are rated to a max of 1.8A, check the specs!
    a friend argued that a certain type of connector would not work with AC current, and insisted on getting the US MADE versions, that he thought were ac-compatible. they are the same..
    morons don't read french..
    at least, that is what i got out of it..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  8. #28
    Raw Wave
    Nov 2009
    Good grief - maybe I do need to translate!
    Read ahead of schedule.
    Many don't understand specs & will see contradictions (eg: st'd USB connector fails spec ie, 1.5A vs 1.8A).
    Anderson Connectors are "not for interrupting current" (eg, SY50A-600V). Aussie moron thought otherwise.
    Nothing to do with AC!!!
    Although this reply was intended for PaulF as a thanks, shall I drop humour & anecdotes & VAS in future? (The malware-lost original reply was clearer.)
  9. #29
    Jan 2008
    i sometimes forget sarcasm doesn't type very well..
    HID retro--100%
  10. #30
    Raw Wave
    Nov 2009
    That's why I don't direct sarcasm at (this forum's) participants - except when it is VERY obvious. (But I'll separate Swedes from Aussies for the moment.)
    If people get confustigated by simple specs, irony & sarcasm have little chance....
  1. usb car charger powered hub?
    By boxlifeusa in forum General MP3Car Discussion
    Last Post: 07-26-2010, 12:22 PM
  2. Powered USB Hub Anyone?
    By Lukeyson in forum General Hardware Discussion
    Last Post: 07-09-2009, 04:54 PM
  3. 5v Powered usb hub help
    By dhantiflag in forum General Hardware Discussion
    Last Post: 06-11-2009, 09:41 AM
  4. Self Powered USB hub that actually works with more than one item!
    By mcoutlawz in forum General Hardware Discussion
    Last Post: 02-26-2009, 08:29 AM
  5. installing a powered USB Hub.....questions?
    By mygti02 in forum Power Supplies
    Last Post: 11-01-2007, 01:05 PM
