Results 1 to 9 of 9
Thread: Recommendation for a SPDT relay
    Jan 2011
    Hi i am in search of a SPDT 1,2,4 - channel relay(comparatively cheaper in price) with small footprint like the SSR or the photomos.. i need it for a multiplexer and a de multiplexer circuitary
    could any one suggest me any links for the same as i have tried a numerous times but was unsuccessful...
    the device needs to
    a. Minimum 5 V DC
    b. Maximum 20 V DC
    c. Maximum source current 150 mA
    d. Maximum sink current 300mA (only for SHORT_TO_GROUND).
    thanking you
    Rajesh Medampudi...
    Raw Wave
    Nov 2009
    I hope someone can because I am totally lost to your requirement....
    (Are they coil or contact voltage specs; a relay will not limit short circuit current; its contact can sink or source and what "channels" - RC or Poles?)
    There are some remote control devices that have similar specs, but the relay part of the is irrelevant.
    Mar 2006
    Colorado, but Canadian!
    I too don't fully understand your requirements. Could you perhaps rephrase the question?
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2011
    hi... thank you for the quick response...
    I am actually looking for some operation like a 2:1 multiplexer. 2 inputs to be selectable with one output.
    the system need follow these specifications that are taken care of by other parts not the Relays... The relay need to be used for multiple functionality at a single pin - 3 - 4 user selectable usages.... including interfacing a Programming voltage in between the specifications and then other signals using CAN or related technology..
    No mechanical parts can be used as the size of the device is a constraint as we need not just one but many relays.... so if possible could you please recommend something with small footprint which can be embedded in a small device
    Thanking you
    Rajesh
    Mar 2006
    Ok, I think I know what you mean. You want a circuit that works like a relay with a NO NC and COMMON. So COMMON and NC are connected when "0" is applied and COMMON and NO are connected when "1" is applied.
    You might be able to use a solid state relay with 3 terminals.
    Jan 2011
    Quote Originally Posted by 2k1Toaster View Post
    Yes i think that is it... but i am having a tough time finding a specific IC for that product and also my system has 6 pins that have upto 4 user selectable funtions... that would make a tremendous no of relays in the board... could you guide me thru this....
    Rajesh
    Mar 2006
    Are these analogue or digital signals being passed through? Can you just use a multiplexer? They do make analogue multiplexers and it sounds like this is what you want perhaps?
    Jan 2011
    my goal was to use a multiplexer that would adhere to the power electronics standards as this would be in between the power ranges from 5-20VDC . although the current is a 150mA and a sink current of 300mA
    My signals are of 5 types...
    a. programming voltage - 5-20Vdc 150mA
    b. ISO 9141/14230 K line / L line
    c. ISO i5765-4/CAN high/low
    d. SCI A/B Engine/Trans ( Tx/Rx )
    e. Short to ground on one pin
    pin 6 - a,c,d
    pin 7 - b,d,d,d(combination of transmitter only for A or B)
    pin 9 - d,a
    pin12 - d,a
    pin14 - c,a,d
    pin15 - b,e,d
    I can see some of them being used with a normal multiplexer but what about the others....
    Rajesh....
    Jan 2011
    there can also be a reverse voltage from the battrey of about 24Vdc for atleast 10 mins...
  1. FAQ: RELAYS; how they work and how to wire it up...
    By FusionFanatic in forum The FAQ Emporium
    Last Post: 06-16-2015, 06:58 AM
  2. Relays
    By FusionFanatic in forum VaultWiki
    Last Post: 09-24-2009, 08:19 AM
  3. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  4. AMP 1.X Phidget Plugin Interface
    By bcohen5055 in forum AMP
    Last Post: 09-06-2007, 01:10 AM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
