Any idea what car or ECU model you are designing for? This would probably help people answer your question.
Hi..
i want to design a vehicle speed converter for car which takes speed signal from ECU of car and convert it to digital format. i don't have car. i don't know what kind of speed signal come out from the ECU of car. I am an Electrical and Electronic engineer. i have experience developing electronic circuit. I want to know the voltage VS speed waveform diagram of the ECU speed out put. Can anybody help me?
Want to:
Dear Bugbyte,
Thank you for your reply.
Proton, Isuzu cars. is different car use different technologies? I have no idea ECU models.
Thanks again
kirupa
Frequency to voltage is easy enough (LM2907/LM2917), and many speed transducers are pulse types - eg Nissans use a 10 pole sensor on the box (20 pulses per cable rev?) and they can be fitted to (older) Isuzus.
Isuzu often use a reed switch mounted in the speedo (I'm not kidding - and it lasts for hundreds of thousands of miles/km!).
As to digital....
Dear OldSpar,
I didn't get answer for my question. i want to know what kind of speed signal come out from the ECU of car?
1) is this pulse? ( different speed has different frequency)
2) is this linear voltage? ( different speed has different voltage)
Hmmmmmmmmmmm....we don't have Protons stateside. Perhaps you can get a pic of one so we can figure out the corresponding model and go from there?
Hi..
Say, now vehicle is moving 20Km/h. i am connecting a oscilloscope to ECU speed output? How will the oscilloscope waveform be? Now i am changing speed to 40Km/h. Now how will the oscilloscope waveform be ?
It is VERY unlikely that you will be able to design this without having access to the car. Why are you developing this for a car you neither own nor have access to? Is this a commercial project?
Want to:
Ditto. Again which ECU?
Or answer this:
How will:
- an analog voltage
- a bitsream (hex or binary or BCD)
- PWM or...
- variable frequency pulses
look on your CRO?
Are you using DC or AC input?
Answer the above (at least 4 answers; 8 if AC/DC variation; extra if hex is different to binary)
... and I'll continue.
Also, which Isuzu ECU puts out a speed signal?
