Results 1 to 10 of 11
Thread: Rotary Switch to Variable Timing Circuit?
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    I need some EE help with a project I am trying.
    What I need is a timing chip whose time(s) are set by rotating a dial.
    Set the dial to 1sec. When you power the circuit (switch) you get a 1sec pulse of power to the output and then it stops.
    Im looking to have a 10-12 position rotary dial connected to a timing chip. How the hell do I go about even starting this project? How does one get EXACT timed pulses from the chip...do I need to program it?
    I need non-crazy times like 1s, 1/100th, 1/1000th etc.
    So, to reiterate my ranting unintelligible self:
    set dial to a certain time
    power on the circuit
    timing chip reads setting on dial and outputs appropriate amount of time in a power pulse
    This will allow me to turn on/off a device with perfect timing I can set.
    HELP!? Are there things already set up like this? Do I need to get a programmable chip and dev board?
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Raw Wave
    Nov 2009
    It all depends on the accuracy & delays you need.
    A 555 timer is analog and uses resistor-capacitor combinations for fractions of a second to many 10's of minutes.
    Otherwise there are programmable timers - check Jaycar.
    Then there's the FB, Arduino, etc.
    Aug 2004
    Floreeda
    Yes, the 555 Ive researched quite a bit. But, unfortunately if it requires different sets of res/cap for each setting on the rotary dial, it defeats the purpose of my project. Itll be too large for the small containing space.
    I was hoping for a rotary dial which sends different "signals" for each different setting. Hexadecimal seems the only way to accomplish this because the 555 is the only other way, and using a normal switch between res/cap banks, isnt gonna cut it. A chip would read the "signal", i.e. setting, and output a pulse of power for a specific length of time.
    Using a dev board, unless it lets me take some chip off and install it as I just described...will again be too big and much overkill.
    Raw Wave
    Nov 2009
    I reckon forget the coded switch.
    It's the timer that will do the decoding (as per normal practice (for single-users)).
    Maybe consider a digital up/down rotary instead (1+3 wire) so you don't need 1+12 inputs (or 1+4 bits) etc.
    Aug 2004
    Floreeda
    I believe this is going to call for a programmable microcontroller I can feed input from a switch and output timed pulses...but what chip, how to program, who knows!!!?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Well you could go with Arduino, they're cheap, and if you know C, you know how to program one. They're fairly easy
    RevFE
    My Shop
    Raw Wave
    Nov 2009
    That was gonna be my recommendation.
    Cheap, and with common open source information.
    But I prefer uPCs over PICs anyhow....
    (And I still prefer assembler LOL!)
    Aug 2004
    Floreeda
    But a dev board is gonna be too big. I need, literally, like a 555 chip thats not analog but programmable.
    Raw Wave
    Nov 2009
    Fine.
    Build your own PIC (8 pin)
    Or use a Stamp uPC.
    There are digital chips that can count down from a binary value. But then you have the problem of providing the binary value....
    You can use ordinary rotary switches with enough diodes - but do you really want that?
    Hence a PIC to do the binary, in which case it may as well do the timing - ie, the lot.
    Aug 2004
    Floreeda
    So, I can have a rotary switch, hexadecimal, which feeds values to a PIC and the PIC then pulses for a set period, sending power to another circuit for that period.
    Dont suppose youve got a direction I could be looking for parts and a programmer?
    The resistor bank with a ordinary switch has been tried, and while I am currently working on it to get it small and into the compact space where this goes, I wanted something less analog.
  1. how to construct a variable dc to dc circuit
    By spookvdub in forum Power Supplies
    Last Post: 03-06-2009, 04:51 AM
  2. Variable Resistors / Rotary Encoders
    By zzzBrett in forum Fusion Brain
    Last Post: 04-12-2008, 01:37 AM
  3. Rotary Encoder Switch Emulation
    By GiODi in forum Hardware Development
    Last Post: 09-01-2006, 10:38 PM
  4. Which Rotary Switch Spins Forever?
    By 2k1Toaster in forum Fabrication
    Last Post: 06-15-2006, 01:10 AM
  5. Help with Constant to Momentary circuit (for power switch) please.
    By b8bboi in forum General Hardware Discussion
    Last Post: 01-11-2006, 11:30 PM
