Results 1 to 7 of 7
Thread: Need ideas to rig a thermostat to get inside/outside temp readings
    Jul 2006
    Northern CA
    Question Need ideas to rig a thermostat to get inside/outside temp readings
    (Posted this at Centrafuse forums too, but no reply, thought I'd try my luck here...)
    For all you electrical and programming nuts out there, I call upon you for help.
    I was thinking of wiring up an Arduino with a 16x2 LCD module and a SHT-21 humidity and temperature sensor so I can get outside and inside temp readings of my '06 Acura RSX Type-S (No my car did not come with one from the factory, damn you newer cars...).
    Some problems I see with this is primarily mounting and wiring. I don't want a bunch of wires running all over the place, and I also don't want the module to placed in a spot that would give me inaccurate readings.
    With that said, anyone mind helping me brainstorm a way to make this project as lightweight as possible but still get the same functionality out of it?
    Oct 2010
    Perth, Western Australia
    Ill be doing a similar thing soon, but utilising Phidgets Sensors, will post my progress soon.
    FLAC -zip-'s Avatar
    Ontario/Canada
    I run a Fusion Brain in my car for inside/outside temp. Very nice little board and you can do a whole lot more if you want to. They sell them here along with the sensors.
    Sound Stage
    Eclipse|MTX|Infinity
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by -zip- View Post
    +1
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2009
    I know that this is not the answer you want... But ten dollars will buy you a wireless thermometer for the house. Disassemble the housing, fab a mount, and done. Save you a ton of time. Most of them come with inside and outside readings.
    Mar 2006
    Quote Originally Posted by natemart View Post
    This probably wins for the K.I.S.S. methods.
    Of course geeks do like their complex and unique setups which that won't gain you. But a nice original idea.
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls
    I am using Arduino to read two LM34 temp sensors. Not the most accurate sensors (at least with minimal components) but definitely good for ambient in/out temps. I am using Open Mobile and a custom made plugin for it. The plugin uses Firmata to communicate with the Arduino. I also added code to the Arduino to compare what the two readings are and if it's cold enough, and if the car has be started remotely, it will turn on my rear defroster. Basically, if input D2 is low and outside temp is < 5c and inside is < 5c then pulse the rear defrost switch. Set flag so it doesn't keep pulsing the switch. This way, if its cold outside but the interior is already warm, no action.
    Anyway, sorry for rambling. Arduino works well for me.
    ZOTAC G43ITX-A-E 2.5ghz Dual Core Celeron 2GB 160GB SSD
    Win7 Ultimate - Remote Starter - Directed HD - Wifi
    Garmin Mobile + MS GPS Puck - LTE WiFi Hotspot
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  1. Replies: 5
    Last Post: 09-13-2009, 11:15 PM
  2. Where to mount Thermostat
    By djurchicprelude in forum FB Sensors
    Last Post: 07-17-2009, 07:53 PM
  3. How to know if O2 sensor readings are bad or not?
    By qewani in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-10-2009, 01:36 AM
  4. Temp controller works on laptop, not on M10000 any ideas?
    By abrookfield in forum Road Runner
    Last Post: 03-12-2006, 01:52 PM
  5. Best Carputer Solution. Ideas Inside!
    By voidunknown in forum Newbie
    Last Post: 08-25-2004, 11:35 AM
Tags for this Thread
