Originally Posted by
OldSpark
USB won't detect - I meant the analog input of whatever smarts you are using - eg, FusionBrain, Audrino etc.
In old days it was called an ammeter.
They used this silly mechanical "guage" called "moving vane"....
You'd connect your (say) 1mA (am)meter between the resistive position sensor and the voltage source (say 12V).
Its 90-degree arm would indicate the position (at whatever 1:1, 1:2 scale etc). For rudders, center- scale was straight ahead.
It uses only a single wire (plus return) despite its amazing bits or resolution (a superior encoding method to digital - at was called analog).
These days we have to cascade two LM3914s etc.
PS - some cars still use those meters - eg, fuel, temp.
