Results 1 to 10 of 13
Thread: motorized potentiometer
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    so i am looking potentiometers and would love to be able to have the option of either sending an analog signal to a fb from my computer or by a dial on my dash.
    I'd have the dial on the dash with a markings from say 1-10. when i turn the dial to '4', the computer would update it's display to '4' and my hydrofoil would go to position '4' via fusionbrain. but.. say i was in front of my tablet (win7 running my front end, fusion brain connected to the usb port) and i wanted to adjust the hydrofoil to '10'. well i'd select '10' on the tablet, the foil would move to 10.... but the pot would be out of sync.
    it seems that the motorized pots just have a dc motor on them... are there any analog potentiometers with a servo or analog input that would turn the pot to a specific position?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2008
    i assume you have seen this site:
    http://www.p3america.com/motorized_p...eters_text.htm
    this model appears to be completely analog:
    http://www.p3america.com/pp/bs275.htm
    the only thing i am a little worried about is the marine usage..
    Dec 2004
    Los Angeles Ca
    i saw this but i 'assumed' these were very expensive seeing how finding them for sale online isn't that easy. and i really didn't see a lot of information about them either. i dont want to break the bank on this feature. if worst comes to worst i could just have an led indicator of some sort to tell me what position the foil is in.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2008
    yeah, i really didn't look for pricing info. though i agree-- there is no way all that planetary gearing and digital circuit design is very cheap..
    ok, take 2- the diy alternative:
    some motors with planetary gearing for slow speed:
    http://www.goldmine-elec-products.co...?number=G16300
    ..and that is as far as i can get-- i don't seem to be able to locate any potentiometers that have shafts passing to both sides of the unit--like what would be needed to duplicate their design..
    and i lied..
    it turns out, you can find anything on ebay:
    http://cgi.ebay.com/ALPS-GENUINE-MOT...item2a0b3c53b8
    search results:
    http://shop.ebay.com/i.html?_nkw=mot...iometer&_rdc=1
    Dec 2004
    Los Angeles Ca
    [edit: i was typing this up before i saw your post, but that is the type of motorized pot i am referring to in my post:]
    hmmm... i could have the fb control the pot... and in turn the output of the pot be read by the fb?
    i plan on setting it up like this:
    the hydrofoil is rotated by a linear actuator. i'll have the fb control the actuator via a set of relays
    a hall effect ic will detect the angular position of the hydrofoil arm. this will give an analog output and be read by the fb which will tell the computer it's position (and therefore when to stop).
    when i enter a certain value in riderunner; hopefully, based on the current reading from the hall effect it'll retract or extend the actuator until it receives the desired value from the hall ic.
    sooo... would it work to loop a 'dumb' motor driven potentiometer into the mix?
    computer control would look like this: turn the pot via 12v motor leads (fb controlled). when the pot reaches a value (lets say value of '2v') the fb will turn off the relays controlling the pot's motor. the fb will also move the actuators till it gets a similar reading from the hall ic.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    so doing some more research, i came across this website:
    http://www.cibomahto.com/2008/02/thi...-input-device/
    i wonder if i can leave it in the off state until the foil moves into position then the fb would power up the servo and move it to the correct position?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2008
    maybe i don't understand servos enough, but if the servo is not powered, where does the voltage come from?
    Dec 2004
    Los Angeles Ca
    well i would only be using the internal pot.
    the more i think about this. all i really need is the motor, gears and pot from the servo. i dont need the 'brains' as long as i can control it via fusion brain. it's basically just a dc motor, a pot and a gearbox right?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2008
    yes, you just described a servo.
    weather this helps you or not, i need to break this down to the needed components:
    well, you absolutely need a pot to control the wedge in certain amounts...
    you need a motor to allow you to adjust the pot remotely.
    with a standard motor, you would def need a gearbox due to the very large steps between motor rotations to allow for a more precise control of the pot-esp so it doesn't just snap between '1' and '10'.
    you could use a stepper motor without a gearbox-- that could have very fine steps, and would not need a gearbox, though controlling it is a little more complex..
    the problem becomes attaching the motor to the pot.
    i don't see any easy way to do this with most pots, as they only have a input shaft on one side.
    -- new idea--
    what if you would install a standard pot directly connected to a gearbox/motor, or stepper motor, and then control the steps from a touchscreen? that way, you are digitally controlling the wedge steps, which would allow either local or remote adjustment..
    oh wait, the entire reason for the physical knob is so you can use that for local adjustments, and so you don't need one other thing to display on the screen. right?
    if you could do it digitally, then there would not be any need for a knob at all...
    (why am i the only one adding to this--i am sure someone else has come across something that should work for this situation)
    Dec 2004
    Los Angeles Ca
    im sorry, my above post was a bit misleading. i was saying that i need the pot, gearbox and motor... from the servo.
    I want the knob for local adjustments and an alternative to using the computer. My current version of this setup is tablet based (win7). I have the tablet connected to network usb hub via a wifi router. This leave the tablet completely unteathered and can be anywhere on the boat. for instance: say my g/f wants to choose some music while she's at the bow of the boat. If i wanted to adjust the foil, it would be great to just turn a dial without having to grab the tablet. On the other hand, i am also going to have a 'preset' skin that will fill the ballasts, and set the foil position (possibly even set the cruise control speed). With that in mind; if i hit the preset from the tablet, the knob would be out of sync.
    my options would to either have a continuous rotating rotary encoder and then some sort of digital dispaly.
    -or-
    a knob that would self adjust based on the foil's position
    i think the latter is cooler.
    I'm thinking that I could bypass the 'brains' in the servo and wire up the fb to the servo's internal dc motor and pot. I would then attach a knob to the servo shaft. when i turn the knob; it would turn the pot, giving the fb an analog input. If i set the foil's position digital from the tablet, the fb would spins the motor and obviously it would in turn also spin the knob and pot.
    do you think that would work?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Linear Potentiometer pinouts
    By ACCLR8N in forum FB Sensors
    Last Post: 02-10-2011, 11:38 PM
  2. Linear Potentiometer
    By MuddyWaters in forum Newbie
    Last Post: 08-08-2009, 11:56 AM
  3. Volume potentiometer
    By yaniv in forum Car Audio
    Last Post: 08-17-2008, 05:46 PM
  4. Guidance on Switch and potentiometer
    By steve2009 in forum FB Sensors
    Last Post: 07-29-2008, 05:07 PM
  5. Potentiometer causes(?) gibberish on LCD
    By hoosier45678 in forum LCD/Display
    Last Post: 10-29-2002, 06:01 PM
