1 Attachment(s)
RadioMAX - FM, AM, WB, RDS USB Car PC Radio + DAB/DAB+, HD Radio, GPS Loger
Ok so i moved threat form Centrafuse to a more competitive battleground :)
We are currently developing TempGP RadioMAX - a universal radio platform specifically designed for CarPC use.
The idea of the project is to create main motherboard that can have plugin modules suitable for specific user needs. Main communication to CarPC is achived via USB 2.0
So far here the specks of main board that we will release shortly.
USB Radio
Unlike many other radio units we decided to do more work and get AM +WB working. Why? Because those bands are used for announcement of traffic condition or in case of emergency at least in US, the WB band is the only one that can be relied upon :) So if we really have pimped out cars this should be required.
Next, after min RadioMAX board is released we will manufacture 2 add on radio chips that will enable following functionality:
- DAB, DAB+ (All but USA)
- HD Radio (USA)
Those are separate clip on modules that can be used based on your country.
On the main board audio will be delivered to CarPC either USB Audio or analog audio (headphone jack) so device can work in different scenarios.
GPS
Next besides Radio as Audio receivers we will have other radio modules available. Foe example more advanced board will have GPS + GLONASS on it so you can get good navigation even in Russia :) We will also add AUX battery to device to we can have hot start to reduce GPS seek time to 0 sec :) Basically GPS will be always on, no need to wait till we find satellites.
GPS Loger
We will have SD card port on the main board so if you hvae GPS module you can enable login feature. This can be used to prove where you have been and what speed you drive with. Of cause logging can be disabled or erased if need. Oh and yes loger can work without car PC as we have independent battery you can just turn log on and drop device to the car you want to spy on :eyebrows:
WiFi + Bluetooth
Module will be available to add support for WiFi and bluetooth. In most cases you don't really need it but if WiFi configured to automatically connect to any open network then you can have reasonably steady Internet connection on PC without figuring out how to do auto connect. With conjunction to GPS you can technically view your car location, just in case you forgot where you have parked. Or it can be used as lowjack ...but no insurance form us :)
EDGE / GPRS / 3G
Same as WiFi but more reliable option to connect your box to Internet.
GPIO - Relay Board + Remote Start + Sensors
Biggest toy of the project is to control your car remotely even when carPC is off. Well you turn on your carPC remotely. The board has low power consumption so it can run off our independent battery. So we can use EDGE/3G or WiFi network to send commands to the car. Ex trigger the relay and remote start your car + carpc. Or maybe sound horn or what ever you can come up with. We will have 4 independent relays they can be triggered remotely or locally through USB just like regular relay board. We might add few sensors or anything that is requested by a community to this add on part. Technically possibilities are limitless
Seams to be lots of text so let me recap road map:
1. Motherboard w/ FM, AM, WB, RDS [End of 2011]
2. Motherbard with Radio + GPS + SD Card [End of 2011]
3. DAB+ Module [Q1 2012]
4. HD Radio Module [Q2 2012]
5. WiFi + BT Module [Q3 2012]
6. EDGE / 3G Module [Q3 2012]
7. GPIO Module [Q4 2012]
If you want to hear sample audio that we did while testing dev board you can hear it on our website.
http://www.tempgp.com/dynamic/?page=24
If you want to speed up the development we will probably start selling preorders once design is finalized.
As to software, it will be GPL Open Source. We will write general windows program to control radio and we will do Centrafuse plugin. All will be open source so if you are developer you will be able to edit or modify or create your own plugins for different front ends.
Drivers: we are planing to release drivers for Win XP, Win 7, Linux, Mac ... maybe Win CE
Rough Price estimates:
RadioMAX basic AM/FM board ~$150-200 USD
RadioMAX GPS Loger borad ~ $250 UDS
RadioMAX DAB/DAB+ Module ~$50
I thin i described project well so if you have any questions comments, donations then let me know ;)
Here is diagram of device concept.
Attachment 64072
