Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Like Tree2Likes
Thread: RFID-Based Auto-lock/unlock System
  1. #41
    Mar 2013
    Florida
    Quote Originally Posted by redheadedrod View Post
    Hey Mickz, since I will be developing my own alarm system for my truck and I am interested in any of those developer boards you are talking about.
    I will likely make use of a standard car start unit and drive that from an ARM based board or Microprocessor such as a Parallax Prop. But having something like this would be great. I will likely start with the sensors from a quality alarm since those are well tested and use them with the system I create.
    If you're going to combine a standard off the shelf unit with your custom one, do yourself a favor and use a unit that accepts analogue inputs instead of just the RF and data ports, that will make testing 10x easier.
    Quote Originally Posted by Mickz View Post
    Yes great way to go. The hardest part of a DIY longer range RFID access system is in making the pocket or key ring transmitter really small. There are a few tiny units starting to appear for just a few dollars, only need a tiny SMD 8 pin micro and a bit of code to make a good package, that will be my next project when I find a really small TX module. Using low duty cycle TX you can get battery life measured in years.
    Keep in mind that companies follow the specifications put in place by the OEMs and outside of aftermarkets versions, no one really offers a long range RF since the OEMs won't use them. The EU has standards for RF and it's a fairly short distance, around 27cm if I remember right.
    -Mark
  2. #42
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by Mark_MES View Post
    -Mark
    That's only true if you are trying to duplicate a system using available RFID tags and the low frequencies used for them. Anything that uses RF to communicate with a device and uses encrypted keys for authentication is still an RFID device but not in the sense of the now current definition for that standard. Long range devices are not energized by an RF field and would use frequencies in the allocated UHF and 2GHz range with the Tag self powered. The tag initiates the communication link not the other way around as with standard close proximity RFID systems.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  3. #43
    May 2012
    Grandville, MI
    I may have actually found an alarm that might work but may require some reverse engineering if I can't get them to let me have access to the protocol.
    Apparently there is a version of a Viper alarm (By Directed) that allows you to access ODBII information as well as the current alarm states and digitally setting of sensors, GPS and a bunch of other stuff. if I can interface directly into it with a computer and not require a service contract it may be worth it to use that alarm and just add some features to it.
    There otherwise is an android app and you have to get a service agreement for it. I will likely try having an ARM based computer access it so I can put up a web server that can display an interactive HTML5 screen that displays all of the information needed.
  4. #44
    Feb 2013
    Western Massachusetts
    I've had a few different exposures to passive RF ID tags and I though I would share my experiences.
    First off, I have set up two different access control systems that use passive RFID chips. In one system, we use small key fobs. In the other system we use badges with the chips imbedded in them. The fobs and the badges both use the same technology and in fact could be used interchangeably if it was so desired. Th range on them from the tagged device to the reader is about 2-3 inches at the most.
    My other exposure was in the form of the implantable chips that many people put in their pets. Most of them wind up in dogs. In my case, I put them in my llamas. Anyway, the "chip" is inside a small glass tube, maybe a bit under 0.1 inches diameter by 0.5 inches diameter. The reader is a hand held thing with a pickup coil about 5" diameter. The range is only a couple inches max.
    Passive has advantages... no batteries to ever replace, but I am thinking for extended range it just doesn't cut it.
    Rick
  5. #45
    Mar 2005
    I would not waste my time and life with this. Just buy a 300$ kit.
    I did it and works great.
  6. #46
    Sep 2009
    Australia
    Quote Originally Posted by cederron View Post
    $160 for a long range off the shelf device made for interfacing with Keyless entry vehicles.
    I can make one for around $30, I just need to get the tag a little smaller. Some of us are playing around with standard short range RFID for other purposes and not just the Vehicle access idea inquired about by some forum users so the discussion will likely continue.
    Hi Rick, yes passive devices powered via an RF field are short range by virtue of legal power limits and size, frequency and power consumption. The disadvantage with passive devices in a vehicle is the fact that the detector in the vehicle is also the transmitter for the power source to the Tag. Not good for long term power without some thoughtful design.
    Powered version of an RFID Tag (totally different to what is now referred to as RFID) is perfect for long range access with virtually no power consumption from the vehicle. Tag battery life is claimed to be measured in years.
  7. #47
    Mar 2013
    Florida
    I'm all for the build-something-on-your-own-spirit that most people here have, but I have to agree with the above statement. You can piece together many different products to make something that's functional or buy a product that was designed from the ground up to do something. Like everything in life, it comes down to time and money.
    -Mark
  8. #48
    Sep 2009
    Australia
  9. #49
    Jun 2010
    Syd, Australia
    Thanks for the link Mark, but your website does not provide any information regarding price or what products you would actually receive. A shortfall of this system is that only one phone can be paired. I guess my wife will just have to walk. I also didnt see any info on as to what rage will the system lock/unlock the car. Is it when bluetooth is our of range/within range (i.e 10m)?
  10. #50
    Mar 2013
    Florida
    Quote Originally Posted by mos33y View Post
    Hey mos33y, since the modules are installed by our retail partners, there is no "module only" pricing. We don't currently have any partners in your neck of the woods yet, sorry about that. A common question is about the fact that we only allow one phone to be paired at a time instead of two specifically for couples. We would love to accomodate people on this, but it opens up a slippery slope on the whole simplicity on the module. I'm not saying it will always be that way, but as of right now it's going to remain single phone per module with the ability to have one module for each person in the same car to provide the function that you're looking for. Range varies slightly depending on the phone and vehicle but averages around 5-15 feet (1.5m-4.5m) on unlock and a little farther on the lock range. We can always add range but most people are happy with the average operating range. Anything else, just ask.
    -Mark
  1. RFID Entry System
    By PaulF in forum Hardware Development
    Last Post: 12-02-2009, 11:54 AM
  2. remote lock/unlock does not work until pc is off
    By jmc1414 in forum Power Supplies
    Last Post: 05-12-2008, 09:27 AM
  3. Single Pulse to Lock and Unlock Using a mechanical latching relay
    By rotarypower101 in forum Hardware Development
    Last Post: 08-16-2006, 02:40 PM
  4. Power up/down with unlock/lock remote
    By Chainjack in forum Hardware Development
    Last Post: 03-01-2006, 06:25 PM
