Hi moss, yes hibernate issue is caused by removal of power from the DAB module in hibernate, after resume the SW thinks the module was reset while playing. An FE really should be designed to allow an option for an application to be closed on Hibernate and reopened on resume because not all external apps used in an FE will do this correctly or at all.
I don’t have this problem as I just tick an option on my FE to do this for me on an app by app basis, some need it and some don’t. However I can code a power off/on with resume into the app and I may do that as soon as I get a spare 20 minutes as it takes time to test it on a couple of machines.
The volume slider thing comes back to using Touch screen control of volume in a vehicle which is a pet dislike of mine, but I understand that sometimes you have no other easy option. I guess this is where a Plugin is required to overlay the FE volume control on the radio app.
I’ll see what I can do with your idea, otherwise I may just have an option in settings to place the volume up/down back on the menu for anyone who needs it until a plug is made. The only thing with adjusting the Radio volume "on the Module" is when you go back to the FE all other volume levels will now be different to the radio so I assume you are using this outside of an FE, that's why I treat it as a preset level.
Apology for this long winded answer but I’m trying to clarify were some of the (strange) programming decisions I make come from, properly a closed and narrow perspective from my world I guess, but I’m willing to change it where I can to help make this app useful for others :wave:
