Page 16 of 30 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 298
Thread: DAB DAB+ FM Digital Radio Development Board
  1. #151
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by johnjore View Post
    Mickz,
    also, an enhancement suggestion:
    The way CF works is you only need to enter the numbers 1 0 4 9 and it figures out its 104.9MHz. Saves pressing the . and the button could be removed?
    JJ
    How do you enter a freq as 88.5 without the dot ?
  2. #152
    Apr 2012
    8 8 5....
    Well... not many of us have FM channels above 799MHz, so anything starting with an 8 is usually below 100MHz... Or?
  3. #153
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Mickz,
    Sorry for late feedback, been busy trying to write a Centrafuse frontend.
    Just tested your app and entering the freq manually now works, but can't save (when dragging the green freq to a preset button, it still strips off everything after the ,)
    JJ
    Quick reply as I have a full day of renovations on. I can rewrite the logic so you won’t have to press the KHz separator.
    When you drag the frequency to the Preset what is the separator displayed as on the top frequency display – I take it that it is a “,” ? If so it's an easy fix.
    BTW I can’t refer to colours any more as every font and colour in the app is now changeable.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  4. #154
    Apr 2012
    Jepp, the freq is shown with a , not . at the top left corner.
    Btw, I've got some code to auto detect the COM port used by the board. Let me know if you want a copy.
    JJ
  5. #155
    Sep 2009
    Australia
    JJ
    Hi JJ, I had a few minutes to look at the code, can you give this a try, drag – drop for “,” and no KHz separator needed (hopefully). I tried it once and uploaded it as I’m out of here again.
    I have auto port on some apps but I didn’t like the 6 second timeout that can occur on some ports when accessed via the DLL, you may not have encounter that yet, or perhaps you found a way around it?
    BTW Thanks for giving the app a workout and the feedback, it really is appreciated.
    Mike.
    Forgot to mention that if you need the app to accept any specific key-codes I’ll happily add them.
  6. #156
    Apr 2012
    Nope, still does not save the full freq.
    Yes, entering 1049 works
    COM port:
    43:28.71> DABFMMonkey:: SetupCOMPortInformation(): SetupCOMPortInformation()
    43:28.95> DABFMMonkey:: SetupCOMPortInformation(): Enumerating USBCOM Devices: 'Communications Port (COM17)' HardwareID: 'USB\VID_04D8&PID_000A\7&25C389C1&0&1'
    43:28.95> DABFMMonkey:: SetupCOMPortInformation(): Match. Found MonkeyBoard on: 'Communications Port (COM17)'
    43:28.96> DABFMMonkey:: SetupCOMPortInformation(): COM Port '\\.\COM17'
    43:28.96> DABFMMonkey: InitializeRadio(): COM Port found and will initialize radio using: '\\.\COM17'
    Takes 0.25 of a second to find the port. No probing of the port required, just look for the correct Hardware ID.
    Code:
            /// <summary>
            ///		Autodetect COM port
            /// </summary>
            /// <return>
            ///		Returns COM Port (Windows format), or empty if not found.
            /// </return>
            private string SetupCOMPortInformation()
                CFTools.writeLog("DABFMMonkey:", "SetupCOMPortInformation()");
                ManagementObjectSearcher searcherPNP = new ManagementObjectSearcher("SELECT * FROM Win32_PnPEntity");
                foreach (ManagementObject mo in searcherPNP.Get())
                    string name = mo["Name"].ToString();
                    // Name will have a substring like "(COM12)" in it.
                    if (name.Contains("(COM"))
                        string HardwareID = mo["DeviceID"].ToString();
                        CFTools.writeLog("DABFMMonkey:", "Enumerating USBCOM Devices: '" + name + "' HardwareID: '" + HardwareID + "'");
                        if (HardwareID.IndexOf(DABFMMonkeyUSBVIDPID) == 0)
                            CFTools.writeLog("DABFMMonkey:", "Match. Found MonkeyBoard on: '" + name + "'");
                            string strPort = name.Substring(name.LastIndexOf("(") + 1, name.LastIndexOf(")") - name.LastIndexOf("(") - 1);
                            //Convert port to Windows format
                            strPort = "\\\\.\\" + strPort;
                            CFTools.writeLog("DABFMMonkey:", "COM Port '" + strPort + "'");
                            // Return port name
                            return strPort;
                        else CFTools.writeLog("DABFMMonkey:", "No Match on: " + name);
                return "";
    JJ
  7. #157
    Sep 2009
    Australia
    Of course, I do that for GPS devices and problem Device restart / initialisation in the FE, don’t know why I didn’t think of it for the DAB Module. Getting old I guess.
    I’ll look at drag drop again, I must of missed something, I fed 104,5 to Station text and it saved it ok.
    I’ll look tomorrow.
    Mike.
  8. #158
    Sep 2009
    Australia
    Hi JJ, getting really tired here but made a quick change to drag-drop before heading off. Hopefully it’s ok now? Only the EXE needed and it’s uploaded. If not Ok I'll look tomorrow.
  9. #159
    Sep 2005
    Mickz, you are an absolute trooper :-) thanks on behalf of all of us for the hard work you're putting in.
    Car news and wallpaper site: www.carfeed.net
  10. #160
    Feb 2012
    UK
    COM port:
    Thanks for that code snippet JJ, very handy.
    I've assumed 'DABFMMonkeyUSBVIDPID' is supposed to be 'USB\VID_04D8&PID_000A'. Is that correct?
    It works for me anyway!
  1. Replies: 1
    Last Post: 04-28-2008, 11:52 PM
  2. On-Board Digital Equalizer
    By Cheekz185 in forum Car Audio
    Last Post: 05-24-2005, 05:47 PM
  3. Frustrated with my digital WW board....
    By Waveblaster785 in forum LCD/Display
    Last Post: 03-12-2005, 04:42 PM
  4. Fried my Digital WW board....
    Last Post: 02-21-2005, 09:26 PM
  5. SB Value Digital I/O Board???
    By RaZor in forum General Hardware Discussion
    Last Post: 04-18-2001, 11:45 PM
